I have a hostgroup I need to add to the Recurring Downtime Schedule, should be simple enough
I asked the application admin who is a contact, to add the maintenance schedule he wanted, and he gets the following message
The hostgroup you specified is not valid for your user account.
I verified this by masquerading as the user in question and the result is the same
So he sent the message back to me and I tried with an Admin acct and the result is the same
So I tried the nagiosadmin acct and the result is the same
I verified the application owners acct was a member of the contact group, and that it is assigned to the hosts / hostgroups
I then checked the users acct
set as a user
Can see all hosts and services is checked
Can access advancedfeatures is checked
What if anything am I missing, I even went through each host and made sure the correct contact groups were added
Im not sure what I am missing I have several hostgroups in a maintenance schedule and have looked at those and the settings are the same without error! I need to try and get this setup today if at all possible
version info Nagios XI 2014R1.1
Add Hostgroup for Recurring Downtime Error
Re: Add Hostgroup for Recurring Downtime Error
So you are not able to schedule a recurring downtime for a hostgroup even when you are logged in as nagiosadmin?
What do you have in the log?
tail -50 /usr/local/nagiosxi/var/recurringdowntime.logBe sure to check out our Knowledgebase for helpful articles and solutions!
can I escalate this to a support ticket nothing in the log file for the hosts /hostgroups
sreinhardt
- -fno-stack-protector
Resolved via remote, likely nagios.cmd issue.
