Receiving The script that failed was: './A-subcomponents'
tfgroup
Post by tfgroup »
Trying to install Nagios XI Centos agent an getting:
attached is the install.log
Re: Receiving The script that failed was: './A-subcomponents
Does this machine not have iptables on it?
If not you could bypass this step by running
touch installed.firewall
./upgrade
tfgroup
Post by tfgroup »
Thanks so much for your response!
I removed the entire linux-nrpe-agent directory and re-installed and had no issues this time.
What I am seeing now is:
CPU Stats NRPE: Unable to read output
Memory Usage NRPE: Unable to read output
Open Files NRPE: Unable to read output
all the other checks are reporting fine.
I have attached the nrpe.cfg and the libexec ls results.
Thanks for your assistance.
abrist
Red Shirt
Post by abrist »
How was nrpe installed on the remote system? With our agent, or through source? Usually, the nrpe daemon is controlled by xinetd, so you may have to edit the xinetd settings to allow your nagios server to access the daemon remotely. See the following doc for more info:
http://assets.nagios.com/downloads/nagi ... utions.pdf
Might be a permissions problem. Can you run the ls again but this time as "ls -l" for the long output?
Also, do you have anything listed in /usr/local/nagios/etc/nrpe? Your current NRPE config looks like it has nothing defined.
tfgroup
Post by tfgroup »
here is the ls -l
and the nrpe.conf file
I ran the linux server wizard and copied the nrpe.conf from the same centos 5.9 server in the cluster that has no issues.
tfgroup
Post by tfgroup »
this is the issue now:
NRPE: Unable to read output on check_nrpe!check_cpu_stats!-a '-w 85 -c 95'
abrist
Red Shirt
Post by abrist »
Can you run the check from the cli?
./check_cpu_stats.sh -w 85 -c 95
tfgroup
Post by tfgroup »
./check_cpu_stats.sh: line 139: [: 0.10: integer expression expected
./check_cpu_stats.sh: line 142: [: 0.10: integer expression expected
./check_cpu_stats.sh: line 152: [: 0.00: integer expression expected
./check_cpu_stats.sh: line 156: [: 0.10: integer expression expected
./check_cpu_stats.sh: line 160: [: 0.10: integer expression expected
./check_cpu_stats.sh: line 164: [: 99.80: integer expression expected
CPU STATISTICS OK: user=0.00% system=0.10% iowait=0.10% idle=99.80% | user=0.00% system=0.10% iowait=0.10%;85;95 idle=99.80%
Post by slansing »
What version of "check_cpu_stats" are you trying to use, can you provide a link to it's exchange listing? I'd like to try and reproduce this. If you could also attach the plugin itself here that would be great.
