I have deployed an instance per the following instructions:
http://assets.nagios.com/downloads/nagi ... -Cloud.pdf
I have configured Nagios to monitor my mysql instance as well as a website. When I click on the monitoring tab of the instance running NagiosXI, it shows that the CPU has been at 100% nearly the entire time the service has been up.
Has anyone else suffered this? Does anyone know what to do to fix this so that the CPU isn't getting chewed up so much by Nagios.
EC2 100% CPU usage for Nagios XI
Re: EC2 100% CPU usage for Nagios XI
Can you run the "top" command on the CLI and post the results?
Here goes. This is showing a 2.6% usage, but when I go to the AWS monitoring tab, it is still saying 100% which you can see in the attached image.
top - 12:32:29 up 3 days, 22:25, 1 user, load average: 0.72, 0.75, 0.72
Tasks: 131 total, 1 running, 130 sleeping, 0 stopped, 0 zombie
Cpu(s): 2.6%us, 0.9%sy, 0.0%ni, 96.2%id, 0.3%wa, 0.0%hi, 0.0%si, 0.0%st
Mem: 604940k total, 432352k used, 172588k free, 10120k buffers
Swap: 0k total, 0k used, 0k free, 60880k cached
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
16723 nagios 20 0 182m 13m 3324 S 5.0 2.2 0:00.15 check_mysql_hea
2164 nagios 20 0 50412 1096 340 S 0.3 0.2 0:42.70 ndo2db
16561 nagios 20 0 217m 22m 7788 S 0.3 3.7 0:00.21 php
16663 ec2-user 20 0 15028 1328 1000 R 0.3 0.2 0:00.05 top
1 root 20 0 19224 468 180 S 0.0 0.1 0:00.36 init
2 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kthreadd
3 root RT 0 0 0 0 S 0.0 0.0 0:00.00 migration/0
4 root 20 0 0 0 0 S 0.0 0.0 0:00.24 ksoftirqd/0
5 root RT 0 0 0 0 S 0.0 0.0 0:00.00 migration/0
6 root RT 0 0 0 0 S 0.0 0.0 0:00.00 watchdog/0
7 root 20 0 0 0 0 S 0.0 0.0 0:00.17 events/0
8 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuset
9 root 20 0 0 0 0 S 0.0 0.0 0:00.00 khelper
10 root 20 0 0 0 0 S 0.0 0.0 0:00.00 netns
11 root 20 0 0 0 0 S 0.0 0.0 0:00.00 async/mgr
12 root 20 0 0 0 0 S 0.0 0.0 0:00.00 pm
13 root 20 0 0 0 0 S 0.0 0.0 0:00.00 xenwatch
14 root 20 0 0 0 0 S 0.0 0.0 0:00.00 xenbus
15 root 20 0 0 0 0 S 0.0 0.0 0:00.00 sync_supers
16 root 20 0 0 0 0 S 0.0 0.0 0:00.00 bdi-default
17 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kintegrityd/0
18 root 20 0 0 0 0 S 0.0 0.0 0:03.88 kblockd/0
19 root 20 0 0 0 0 S 0.0 0.0 0:00.00 ata/0
20 root 20 0 0 0 0 S 0.0 0.0 0:00.00 ata_aux
21 root 20 0 0 0 0 S 0.0 0.0 0:00.00 ksuspend_usbd
22 root 20 0 0 0 0 S 0.0 0.0 0:00.00 khubd
23 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kseriod
24 root 20 0 0 0 0 S 0.0 0.0 0:00.00 md/0
25 root 20 0 0 0 0 S 0.0 0.0 0:00.00 md_misc/0
26 root 20 0 0 0 0 S 0.0 0.0 0:00.00 khungtaskd
27 root 20 0 0 0 0 S 0.0 0.0 0:08.57 kswapd0
28 root 25 5 0 0 0 S 0.0 0.0 0:00.00 ksmd
29 root 20 0 0 0 0 S 0.0 0.0 0:00.00 aio/0
30 root 20 0 0 0 0 S 0.0 0.0 0:00.00 crypto/0
35 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kthrotld/0
37 root 20 0 0 0 0 S 0.0 0.0 0:00.00 khvcd
38 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kpsmoused
39 root 20 0 0 0 0 S 0.0 0.0 0:00.00 usbhid_resumer
147 root 20 0 0 0 0 S 0.0 0.0 0:17.48 jbd2/xvde1-8
148 root 20 0 0 0 0 S 0.0 0.0 0:00.00 ext4-dio-unwrit
213 root 16 -4 10780 516 52 S 0.0 0.1 0:00.03 udevd
404 postgres 20 0 212m 5732 3532 S 0.0 0.9 0:01.32 postmaster
412 root 18 -2 10776 516 52 S 0.0 0.1 0:00.00 udevd
415 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kstriped You do not have the required permissions to view the files attached to this post.
sreinhardt
- -fno-stack-protector
Your top looks pretty darn normal, but I agree the ec2 screen is a bit odd. If you wouldn't mind, let's go ahead and run the nagiostats and nagios xi server wizards against localhost. This should allow us to collect some additional system info on a continual basis and see if the ec2 metrics match up. Just a note, you don't need to set notifications on any of this, it's purely for statistics unless you want to be notified for these.
Ok, I've run for a day.
Here's the current info:
Last Update: Tue Jul 15 2014 10:38:38 GMT-0700 (PDT)
Nagios BPI v2.31
Nagios Enterprises, LLC
BPI Documentation
Manually Edit Config
Essential group members are denoted with: **
Ok Local Services URL Group health is 100.00% with 0 problem(s) Example BPI Group Edit Delete
Ok localhost Current Load
OK - load average: 0.67, 0.61, 0.57
Ok localhost Current Users USERS OK - 0 users currently logged in
Ok localhost HTTP HTTP OK: HTTP/1.1 200 OK - 3193 bytes in 0.002 second response time
Ok** localhost PING PING OK - Packet loss = 0%, RTA = 0.07 ms
Nagios BPI v2.31
BPI Documentation
- Box293
- Too Basu
Are you able to view a graph that shows actual CPU usage as MHz instead of a percentage?mengerink wrote:When I click on the monitoring tab of the instance running NagiosXI, it shows that the CPU has been at 100% nearly the entire time the service has been up
Just trying to look at things from a different angle.
No, I do not seem to be able to change the units on the graph.
I believe these two articles are of interest:
http://www.axibase.com/cloud/2010/07/22 ... tolen-cpu/
http://stackoverflow.com/questions/1170 ... -going-off
Essentially, top might be lying because the VM "steals" CPU time in order to run other things. The guest doesn't notice but the host does.
