Hi there,
Since i update to latest version of nagios (2014R1.2) all notification are sent to the contact that i provide in the template but i have those new 2 adresses: <[email protected]>; -[email protected].
How can i remove those adresse?
Regard
PO
Notification problem after update
Re: Notification problem after update
Are you saying those two contacts are now in the template? Or they just exist in general? Either way you can delete contacts or edit templates in the CCM.
nevermind i found the problem you can delete this thread sorry !
