I just updated our Nagios XI from 2012R2.9 to 2014R1.2 on a 64bit virtual machine.
I have attached the results of the upgrade script as a text file and our Nagiosxi system profile as a zip file.
It looks like it had a problem with the config files.
When I logged into the web interface I did not get a “Finish Upgrade” button, but at the bottom of the screen it says Nagios XI 2014R1.2.
It appears to be monitoring everything that was being monitored before the update, but we are unable to make any additions to the database.
Thank you,
John
Upgrading from Nagios XI 2012R2.9 to 2014R1.2
John.colquitt
- Box293
- Too Basu
Re: Upgrading from Nagios XI 2012R2.9 to 2014R1.2
Run through the steps in this FAQ to see if it fixes your problem:
http://support.nagios.com/wiki/index.ph ... 14_Upgrade
Specifically the "CONFIG ERROR!" During 2014 Upgrade section.
