nagios 4.0.6 - init script bug
GeoffMontee
Post by GeoffMontee »
I'm compiling Nagios 4.0.6 from source in a CentOS 6 environment in which I don't have root or sudo privileges. Therefore, Nagios only has a few users, groups, and directories it can work with.
I compiled with the following:
./configure --prefix=/opt/nagios --with-nagios-user=monitor --with-nagios-group=monitor --with-command-user=monitor --with-command-group=monitor --with-init-dir=/home/monitor/scripts --with-lockfile=/home/monitor/nagios.lock --with-httpd-conf=/home/monitor/conf/httpd
make all
make install
mkdir -p /home/monitor/scripts
make --ignore-errors install-init
make install-commandmode
make install-config
mkdir -p /home/monitor/conf/httpd
make --ignore-errors install-webconf
make install-exfoliation
Then I try to start nagios, and get permission denied errors:
> bash /home/monitor/scripts/nagios start
Starting nagios: /home/monitor/scripts/nagios: line 89: /var/run/nagios.configtest: Permission denied
chmod: cannot access `/var/run/nagios.configtest': No such file or directory
touch: cannot touch `/var/lock/subsys/nagios': Permission denied
There seems to be several places in the init script that ignore configure flags and opt for the standard Red Hat locations instead. Some examples:
  1. Line 63: NagiosLockDir is set to "/var/lock/subsys" despite setting --with-lockfile during configure.
  2. Line 89-90, 97-98, 105-106: Config test tries to work with /var/run/nagios.configtest, despite setting --with-prefix during configure.
For my current setup, I can obviously alter the init script to make it work for myself. But I thought I would report this bug, so you could fix it in future releases.
This is unrelated, but you'll notice that I had to pass --ignore-errors to make during two of the steps. To avoid derailing this thread, I'll post the issue that caused that in a separate thread.
abrist
Red Shirt
Re: nagios 4.0.6 - init script bug
Post by abrist »
I will bring one of our core devs into this thread. Could you by chance open an issue on github as well?
https://github.com/NagiosEnterprises/nagioscore/issues
GeoffMontee
Thanks for the response. Posted as issue #7.
Post by slansing »
Great! Just keep an eye on that tracker link for an update from the Devs when they have an answer for you. We can likely chalk this up to non-standard usage, but they will let you know. Thank you for posting the link for others in the future!
