I can't seem to find much about monitoring a particular folder on a Windows system, such as c:\work for size. Is there a simple method of doing this?
Regards,
Randy
Nagios XI 2012R2.7
Redhat 6.4
Folder Sizes on Windows
Re: Folder Sizes on Windows
I believe this plugin can do what you are looking for
http://exchange.nagios.org/directory/Pl ... bs/details
intelXIadmin
oops, I just found out my users want more that just size warnings:
I need to know if a folder has increased by x megabytes in y time. So, if c:\work was 1500mb and 1 hr later it increases by 500mg then flag a critical or warning alert.
Regards,
Randy.
Regards,
Randy.
sreinhardt
- -fno-stack-protector
Well that won't do what you want then. Giving exchange a quick look over, I don't see anything that will do folder size delta for windows. You could make this store the results of the last check in a file and compare them, or rewrite the entire thing in powershell(my preference) and do it in a more sane manor to handle the deltas as well.
