HI there,
I have 3 alert right now and they have all the same ip adresse. When i try to delete the one i dont need in the CCM, i cant find them. I know soneone working here i rename them without the renaming Tools. Seem like the database is curupted.
How can i fix that.
Regard
PO
Running 2014R1.2
Database Coruption after renaming host without the tool
Re: Database Coruption after renaming host without the tool
Have you tried searching for the actual host alias or name in the CCM? And not the address? Search for 'CB_Cisco 1811' does it not display? If not, you may have a ghost host, in which case, follow these steps:
http://support.nagios.com/wiki/index.ph ... t_Hosts.29
