Just curious as to when we can expect mod_gearman to be patched or re-compiled with the applied patch into rpm for our nagios4 core?
with the latest version compatible with nagios4, there is a bug and workaround for perfdata... this is fine for now, but when can I expect to be able to upgrade and remove all the "\n" in our service status text string... more of a cosmetic item, I know, but for enterprise monitoring, I would hope someone would be correcting this for us XI2014R customers who have upgraded from 2012 with intensive perl use cases.
Cheers,
mod_gearman nagios4 \n fix
Re: mod_gearman nagios4 \n fix
I am actually testing a beta build of a patched gearman rpm atm. More news soon, like in a week or less
- tylerhoadley
excellent... thank you sir
..If you are looking for beta tester, I have a dev environment, I can install/upgrade then test with before you release out for an enterprise environment.
Tested by OP in the following thread: http://support.nagios.com/forum/viewtop ... 16&t=29128
