I am use Nagios XI 2012R2.9. I need to enable sound alerts at the Nagios XI interface. I see that have a Firefox plugin "Nagios Checker" that can help us with this.
I need to configure Nagios Checker with the locale of status.cgi.
[HELP] Enabling audio alerts at Nagios XI Interface
Re: [HELP] Enabling audio alerts at Nagios XI Interface
Well I think it gave you the answer right there in the addon:
So something like this:
only with your IP address instead of mine.
http://192.168.1.100/nagios/cgi-bin/status.cgiYou do not have the required permissions to view the files attached to this post.
Thanks! I have already use this but not work.
Some hint?
Some hint?
Well, that is i the correct path to the cgi. Are your credentials correct? Have you logged into *core* on this box recently?
Any plugin available for IE?
5 x Nagios 5.6.9 Enterprise Edition
RHEL 6 & 7
rrdcached & ramdisk optimisation
RHEL 6 & 7
Plugins in IE tend to be few and far between compared to Firefox and Chrome. A Google search didn't come up with anything for IE, and I know we didn't do anything in-house for it.
