Service Alerts being sent out when host is down
rajasegar
Post by rajasegar »
Nagios XI 2014R1.2
This morning we have network issues and service alerts were being sent out even though the host was timing out.
Please advice where to check on this?
Thanks.
5 x Nagios 5.6.9 Enterprise Edition
RHEL 6 & 7
rrdcached & ramdisk optimisation
Re: Service Alerts being sent out when host is down
Post by Box293 »
For the host that was timing out, what are the values for:
  • Check Interval
    Retry Interval
    Max Check Attempts
rajasegar
Post by rajasegar »
Box293 wrote:For the host that was timing out, what are the values for:
  • Check Interval
    Retry Interval
    Max Check Attempts
Check Interval - 5 minutes
Retry Interval - 5 minutes
Max Check Attempts - 2
RHEL 6 & 7
Post by Box293 »
Was the host in a hard state when the service alerts were being sent out?
With your current settings, the host has to return a warning or critical state twice before it goes into a hard state and supresses service alerts. To explain with dummy times:
1.00pm = Host is checked and is OK, next check is 1.05pm
1.01pm = Host goes down, Nagios does not yet know about it
1.05pm = Host is checked and is critical, 1st attempt so goes into a soft state, no host alerts sent yet, next check is 1.10pm
1.10pm = Host is checked and is critical, 2nd attempt so goes into a hard state, host alerts sent and service alerts are supressed
You can see by this example. service alerts will continue to be sent from 1.01pm through to 1.10pm when the host goes into a hard state.
Does this match up with the Host Alert History?
  • Host Status Detail
    Advanced Tab
    See this host in Nagios Core
    View Alert History For This Host
rajasegar
Post by rajasegar »
Box293 wrote:Was the host in a hard state when the service alerts were being sent out?
    Advanced Tab
Yes, what you are saying makes sense.
How do I stop sending out alerts even with Host in Soft State?
RHEL 6 & 7
abrist
Red Shirt
Post by abrist »
rajasegar wrote:How do I stop sending out alerts even with Host in Soft State?
Decrease the host retries to 0. This way when the host fails it will be immediately a HARD problem state.
rajasegar
Post by rajasegar »
This will cause too many false alerts.
I know theoretically it should not but it does especially for network flapping issues. Sometimes about 50% more false alerts.
RHEL 6 & 7
Post by Box293 »
Your other option is to configure your service checks with more retries / intervals so they will not go into a hard state until after the host does. For example:
Host
Service
Max Check Attempts - 3
For the services, with 3 max check attempts, it would take 15 minutes for a service to go into a hard state and by that time the host would have gone into a hard state.
rajasegar
Post by rajasegar »
Box293 wrote:Your other option is to configure your service checks with more retries / intervals so they will not go into a hard state until after the host does. For example:
Host
Service
Will explore this but most of them want notification in single poll especially those checking log files.
RHEL 6 & 7
Post by Box293 »
I meant to put Max Check Attempts - 2 for the host, I editied it so it makes sense.
