NRPE: Unable to read output check_load
Today i had the same problem when trying to check_load using this command :
/usr/lib/nagios/plugins/check_nrpe -H server43012x -c check_load
After reproduce in every post that i;m search still can't solve this. Does anyone know how to fix this ?
Thanks.
Mod Edit: Also mentioned here - http://support.nagios.com/forum/viewtop ... 05#p106405
Thanks.
Re: NRPE: Unable to read output check_load
Can you attach your nrpe.cfg from that remote host here so we can see your command definition? Thanks!
The command from the remote host looks good
# /usr/lib/nagios/plugins/check_load -w 15,10,5 -c 30,25,20
CRITICAL - load average: 23.66, 23.07, 22.93|load1=23.660;15.000;30.000;0; load5=23.070;10.000;25.000;0; load15=22.930;5.000;20.000;0;
Thx.
Thx.
nrpe.txt- nrpe configuration
- (7.86 KiB) Downloaded 620 times
- Box293
- Too Basu
What happens when you test if NRPE is listening?
/usr/lib/nagios/plugins/check_nrpe -H server43012xAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
^ Ithinkg looks good
~# /usr/lib/nagios/plugins/check_nrpe -H server43012x
NRPE v2.15
Any solution ?
Thanks.
NRPE v2.15
Any solution ?
Thanks.
- Box293
- Too Basu
We know that NRPE is listening so thats good.
I noticed in your nrpe.cfg file that the nrpe_user is defined as "nrpe".
Also, lets check some file permissions:
When executing this command on the remote host, are you doing it as the nrpe user?pianunix wrote:The command from the remote host looks good
su nrpe
/usr/lib/nagios/plugins/check_load -w 15,10,5 -c 30,25,20Code: Select all
ls -al /usr/lib/nagios/plugins/As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
No i didn't.
Should i use nrpe user for this ?
Fyi: on the debian machine i was sucessfull doing this, by adding this line into /etc/sudoers on the remote host.
But when i trying on centos machine this trick didn't work at all.
Thanks.
No i didn't.
# su nrpe
This account is currently not available.Code: Select all
# id nagios
uid=496(nagios) gid=497(nagios) groups=497(nagios)Fyi: on the debian machine i was sucessfull doing this, by adding this line into /etc/sudoers on the remote host.
nagios ALL=(ALL) NOPASSWD:/usr/lib/nagios/plugins/check_loadThanks.
Is there any reason why you changed the defalt nrpe user/group from nagios to nrpe?
Have you tried changing the following two lines from this:
to this:
and restarting the daemon?
nrpe_user=nrpe
nrpe_group=nrpeCode: Select all
nrpe_user=nagios
nrpe_group=nagiosBe sure to check out our Knowledgebase for helpful articles and solutions!
Still wont work at all.
turboscrew
One way to check further is to set "debug=1" in your nrpe.cfg.
Then you can check the last lines of "journalctl --system" (works like 'less')
It should output something like:
Jul 25 23:07:29 nrpecomputer nrpe[9645]: Connection from 127.0.0.1 port 44715
Jul 25 23:07:29 nrpecomputer nrpe[9645]: Host address is in allowed_hosts
Jul 25 23:07:29 nrpecomputer nrpe[9645]: Handling the connection...
Jul 25 23:07:29 nrpecomputer nrpe[9645]: Host is asking for command 'check_all_disks' to be run...
Jul 25 23:07:29 nrpecomputer nrpe[9645]: Running command: /usr/lib64/nagios/plugins/check_disk -w 20% -c 10% -p /dev/vda
Jul 25 23:07:29 nrpecomputer nrpe[9645]: Command completed with return code 0 and output: DISK OK - free space: / 8139 MB (85% inode=92%);| /=1373MB;7960;8955;0;9951
Jul 25 23:07:29 nrpecomputer nrpe[9645]: Return Code: 0, Output: DISK OK - free space: / 8139 MB (85% inode=92%);| /=1373MB;7960;8955;0;9951
Jul 25 23:07:29 nrpecomputer nrpe[9645]: [30B blob data]
