Getting the following error when updating from 2014R1.2 to 2014R1.3:
---- Starting Nagios XI Backup ----
No entry for terminal type "unknown";
using dumb terminal settings.
Backing up Core Config Manager (NagiosQL)...
tar: Removing leading `/' from member names
Backing up Nagios Core...
tar: /usr/local/nagios/var/rw/nagios.qh: socket ignored
tar: /usr/local/nagios/var/ndo.sock: socket ignored
tar: /usr/local/nagios/share/perfdata/webrac1.sfmic.com/_home_Disk_Usage.rrd: file changed as we read it
tar: /usr/local/nagios/share/perfdata/webrac1.sfmic.com: file changed as we read it
Backing up Nagios XI...
Backing up MRTG...
Backing up MySQL databases...
mysqldump: Got error: 145: Table './nagios/nagios_logentries' is marked as crashed and should be repaired when using LOCK TABLES
Error backing up MySQL database 'nagios' - check the password in this script!
Update error
Re: Update error
Looks like you have some crashed tables, after running through this, you should be good to upgrade:
Let us know if you have any problems!
/usr/local/nagiosxi/scripts/repair_databases.sh
