wproc seems to be choked
ibrewster
Post by ibrewster »
I am working on upgrading my monitoring system from OpenBSD 5.4, nagios 3.5.0, to OpenBSD 5.5, nagios 4.0.7. Previously, I had compiled and installed nagios from the OpenBSD ports tree, however this time I am having to compile and install nagios manually, since the version in ports (4.0.1) is broken (it doesn't set environment variables correctly). I have been able to get nagios built and installed properly, and moved my config across, but while nagios starts, the nagios.log is filled with entries like the following:
[1406055886] Unable to run check for service 'Latency and Loss' on host 'eavdz-sw00'
[1406055886] wproc: 'Core Worker 26292' seems to be choked. ret = 4096; bufsize = 6725: errno = 2 (No such file or directory)
Of course it doesn't tell me WHAT file or directory it is looking for - it's quite possible I have a path wrong somewhere, or need to create a folder. In any case, this is all I see in my logs, and from what I can tell no status is ever updated. What did I do wrong, and how can I fix this? Thanks.
ibrewster
Re: wproc seems to be choked
Post by ibrewster »
Quick update: I discovered that running off environment Macros "fixed" the issue. Of course, the ability to HAVE environment macros in the first place is the whole reason I downloaded and compiled the latest version, rather than using the version from the ports tree, so that is not a solution. But maybe it can help point someone who knows more about nagios to a solution?
This seems to be a bug that is fixed in 4.0.3.
http://tracker.nagios.org/view.php?id=577
ibrewster
Post by ibrewster »
lmiltchev wrote:This seems to be a bug that is fixed in 4.0.3.
Obviously not, since as I clearly stated I am building/running 4.0.7 :)
My bad - I thought you were running 4.0.1. I definitely need more coffee... :) We will have to do some more digging into this and see if this is actually fixed.
ibrewster
Post by ibrewster »
lmiltchev wrote:My bad - I thought you were running 4.0.1. I definitely need more coffee... :) We will have to do some more digging into this and see if this is actually fixed.
Yeah, I had mentioned 4.0.1, since that is the (broken) version the OpenBSD ports tree currently. But that was just as my motivation for downloading and compiling 4.0.7 myself :) Thanks for the digging! Let me know if I can provide more information to help. I did note that the error is SLIGHTLY different - mine is saying file not found, whereas the bug report says Resource temporarily unavailable. Other than that though, it does look very similar.
abrist
Red Shirt
Post by abrist »
You may have a new, though slightly related issue. Can you open up a new bug report and make sure to specify that the wording of the error is different than the bug fixed in 4.0.3
