CHECK_NRPE: Received 0 bytes from daemon. Check the remote s
hillhealthcenter
I'm seeing this warning a lot lately for different hosts.
"CHECK_NRPE: Received 0 bytes from daemon. Check the remote server logs for error messages."
I've attached my system profile.
Thanks so much,
Tom
Tom
lcontreras
Re: CHECK_NRPE: Received 0 bytes from daemon. Check the remo
Open your nrpe.cfg file and set dont_blame_nrpe=1
Then restart xinet.d service.
hillhealthcenter
lcontreras,
Thanks for getting back to me.
I made the change that you suggested. However, I'm still receiving the same warning from random Windows hosts.
Thanks so much,
Tom
Tom
hillhealthcenter
lcontreras,
Should be using NSVlient++ 0.3 or 0.4 on my windows hosts?
Thanks so much,
Tom
Tom
Both should work with check_nrpe but you need to enable the NRPE listener first. Have you completed the steps, outlined in this document? What is the error that you are getting the nsclient.log?Should be using NSVlient++ 0.3 or 0.4 on my windows hosts?
hillhealthcenter
2014-07-23 16:43:58: e:d:\source\nscp\trunk\modules\checkexternalscripts\commands.hpp:91: Failed to parse arguments for command 'check_updates', using old split string method: unknown escape sequence: cmd /c echo scripts\Check-Updates.ps1; exit $LastExitCode | powershell.exe -command -Thanks so much,
Tom
Tom
Could you post the external scripts command from your nsclient config for this check?
hillhealthcenter
Param(
[Parameter(Mandatory=$false)][Int]$GracePeriod
Function Check-NewUpdates {
.SYNOPSIS
Get list of available Windows updates.
.DESCRIPTION
Use Check-NewUpdates to determine if there are additional updates that have not been applied to a Microsoft Windows machine.
.PARAMETER Type
Pre-search criteria. Finds updates of a specific type, such as 'Driver' and 'Software'. Default value contains all updates.
.EXAMPLE
Get list of available updates from Microsoft Update Server, no matter how recent the last check was.
PS D:\Powershell> .\Check-Updates.ps1
35 Days since last update.
2 Critical Updates:
KB2792100
KB2797052
6 Important Updates:
KB2778344
KB2789642
KB2789645
KB2790113
KB2799494
KB954430
1 Moderate Updates:
KB2790655
4 Unknown Updates:
KB890830
KB915597
KB971033
KB973688
.EXAMPLE
Get list of available updates from Microsoft Update Server, if last check was outside of grace period.
PS D:\Powershell> .\Check-Updates.ps1 50
35 Days since last update. Within grace period
2 Critical Updates:
KB2792100
KB2797052
KB2778344
KB2789642
KB2789645
KB2790113
KB2799494
KB954430
1 Moderate Updates:
KB2790655
4 Unknown Updates:
KB890830
KB915597
KB971033
KB973688
.NOTES
Author: Spenser Reinhardt
Company: Nagios Enterprises LLC
Version: 1.0
.LINK
http://www.nagios.com
Param(
## Start Main Script
$OSVersion = Check-OSVersion
If ( $GracePeriod -ne $null ) { #If GracePeriod is set
$UpdateTime = Check-LastUpdate $GracePeriod
If ($UpdateTime.IsOver -eq $true) { #If is outside of GP, check for updates and return
$Updates = Check-Updates
$Output = Create-Output $Updates
ElseIF ($UpdateTime.IsOver -eq $false) { #If within GP, return days since check with OK status
$Output = @{}
$Output.Output = "Within grace period."
$Output.ExitCode = 0
} #ends if GP is set
Else { # If no grace period has been set, check and return
$UpdateTime = Check-LastUpdate 0
$days = $UpdateTime.Days
$OutputString = $Output.Output
Write-Output "$days Days since last update. $OutputString"
Exit $Output.ExitCode
# Function to check OS Version and return string with 7 or XP depending. Returns [string]
Function Check-OSVersion {
$version = Get-ItemProperty 'HKLM:\SOFTWARE\Microsoft\Windows NT\CurrentVersion'
switch ($($version.CurrentVersion).split(".")[0]){
6 { [string]$Return = "7" }
5 { [string]$Return = "XP" }
} ## End of Switch to check versioning
Return $Return
} ## End of Function
# Checks for updates using winupdate api, returns hashtable with all listed updates not including hidden ones. Returns [Array](KBImportance)KB and [Int](KBImportance)Number
Function Check-Updates {
$Return = @{}
[string]$Return.CriticalKB = ""
[Int]$Return.CriticalNumber = 0
[string]$Return.ImportantKB = ""
[Int]$Return.ImportantNumber = 0
[string]$Return.ModerateKB = ""
[Int]$Return.ModerateNumber = 0
[string]$Return.LowKB = ""
[Int]$Return.LowNumber = 0
[string]$Return.UnknownKB = ""
[Int]$Return.UnknownNumber = 0
$Updates = $( New-Object -ComObject Microsoft.Update.Session ).CreateUpdateSearcher().Search("IsAssigned=1 and IsHidden=0 and IsInstalled=0").Updates
$Updates | Where {$_.MsrcSeverity -eq "Critical" } | ForEach-Object { $_.KbArticleIDs } | Sort -Unique | ForEach-Object {
$Return.CriticalNumber++
$Return.CriticalKB += "KB"+$_+"\n"
$Updates | Where {$_.MsrcSeverity -eq "Important" } | ForEach-Object { $_.KbArticleIDs } | Sort -Unique | ForEach-Object {
$Return.ImportantNumber++
$Return.ImportantKB += "KB"+$_+"\n"
$Updates | Where {$_.MsrcSeverity -eq "Moderate" } | ForEach-Object { $_.KbArticleIDs } | Sort -Unique | ForEach-Object {
$Return.ModerateNumber++
$Return.ModerateKB += "KB"+$_+"\n"
$Updates | Where {$_.MsrcSeverity -eq "Low" } | ForEach-Object { $_.KbArticleIDs } | Sort -Unique | ForEach-Object {
$Return.LowNumber++
$Return.LowKB += "KB"+$_+"\n"
$Updates | Where-Object {!$_.MsrcSeverity} | ForEach-Object { $_.KbArticleIDs } | Sort -Unique | ForEach-Object {
$Return.UnknownNumber++
$Return.UnknownKB += "KB"+$_+"\n"
Return $Return
} # Ends Function
# Checks if last update installed was within Grace Period, Returns [Int]Days and [Boolean]IsOver
Function Check-LastUpdate {
Param([Parameter(Mandatory=$true)][Int]$GracePeriod)
$Return = @{}
#Gets DateTime Object with last update installed
if ($(Check-OSVersion) -eq "7") {
$WMIData = Get-WmiObject -Class Win32_QuickFixEngineering
Else { $WMIData = $null }
If ( $WMIData -eq $null ) { ## No data for installed on, run update check, might be issue with os version too
$Return.Days = 0
$Return.IsOver = $true
Else { ## has data and should be processed
[DateTime]$Date = $( $WMIData | Sort InstalledOn -Descending -Unique | Select InstalledOn -First 1 ).InstalledOn
$Return.Days = $( $(Get-Date) - $Date).Days
If ( $Return.Days -gt $GracePeriod ) { #if true has been longer than grace period
Else { #if within Grace Period
$Return.IsOver = $false
Return $Return
# Creates write-ouput text for returning data to nagios, Returns [int]ExitCode and [string]Output
Function Create-Output {
Param ( [Parameter(Mandatory=$true)]$Updates )
$Return = @{}
[Int]$Return.ExitCode = 3 # Sets to unknown by default
[String]$Return.Output = "Output creation failed, something is not working!"
If ( $Updates.CriticalNumber -gt 0 ) { # If any Critical updates, writes output line and sets exit code to 2(critical)
$Return.ExitCode = 2
$Return.Output = "`n"+$Updates.CriticalNumber+" Critical Updates:"
$Return.Output += "`n"+$Updates.CriticalKB.Replace("\n","`n")
If ($Updates.ImportantNumber -gt 0) {$Return.Output += ""+$Updates.ImportantNumber+" Important Updates:`n"
$Return.Output += $Updates.ImportantKB.Replace("\n","`n")
If ($Updates.ModerateNumber -gt 0) {$Return.Output += ""+$Updates.ModerateNumber+" Moderate Updates:`n"
$Return.Output += $Updates.ModerateKB.Replace("\n","`n")
If ($Updates.LowNumber -gt 0) {$Return.Output += ""+$Updates.LowNumber+" Low Updates:`n"
$Return.Output += $Updates.LowKB.Replace("\n","`n")
If ($Updates.UnknownNumber -gt 0) {$Return.Output += ""+$Updates.UnknownNumber+" Unknown Updates:`n"
$Return.Output += $Updates.UnknownKB.Replace("\n","`n")
} #Ends Critical If
ElseIf ( $Updates.ImportantNumber -gt 0 ) { # If any Important updates, writes output line and sets exit code to 2(critical)
$Return.Output = "`n"+$Updates.ImportantNumber+" Important Updates:"
$Return.Output += "`n"+$Updates.ImportantKB.Replace("\n","`n")
} #Ends Important If
ElseIf ( $Updates.ModerateNumber -gt 0 ) { # If any Moderate updates, writes output line and sets exit code to 1(Warning)
$Return.ExitCode = 1
$Return.Output = "`n"+$Updates.ModerateNumber+" Moderate Updates:"
$Return.Output += "`n"+$Updates.ModerateKB.Replace("\n","`n")
} #Ends Moderate If
ElseIf ( $Updates.LowNumber -gt 0 ) { # If any Low updates, writes output line and sets exit code to 1(Warning)
$Return.Output = "`n"+$Updates.LowNumber+" Low Updates:"
$Return.Output += "`n"+$Updates.LowKB.Replace("\n","`n")
} #Ends Low If
ElseIf ($Updates.UnknownNumber -gt 0) { # If number of unknown severity updates are available sets exit to 1(warning)
$Return.Output = "`n"+$Updates.UnknownNumber+" Unknown Updates:"
$Return.Output += "`n"+$Updates.UnknownKB.Replace("\n","`n")
ElseIf ( ($Updates.CriticalNumber -eq 0) -and ($Updates.ImportantNumber -eq 0) -and ($Updates.ModerateNumber -eq 0) -and ($Updates.LowNumber -eq 0) -and ($Updates.UnknownNumber -eq 0) ) { #If no updates, writes output and sets exit 0(OK)
$Return.ExitCode = 0
$Return.Output = "There are no updates to be done."
Return $Return
Check-NewUpdates $GracePeriodThanks so much,
Tom
Tom
Actually, post the entire NSC.ini (or nsclient.ini) file. Hide the sensitive info (IPs, passwords, etc.).
hillhealthcenter
; Undocumented section
[/modules]
; CheckDisk - CheckDisk can check various file and disk related things. The current version has commands to check Size of hard drives and directories.
CheckDisk = 1
; Event log Checker. - Check for errors and warnings in the event log. This is only supported through NRPE so if you plan to use only NSClient this wont help you at all.
CheckEventLog = 1
; Check External Scripts - A simple wrapper to run external scripts and batch files.
CheckExternalScripts = 1
; Helper function - Various helper function to extend other checks. This is also only supported through NRPE.
CheckHelpers = 1
; Check NSCP - Checkes the state of the agent
CheckNSCP = 1
; CheckSystem - Various system related checks, such as CPU load, process state, service state memory usage and PDH counters.
CheckSystem = 1
; CheckWMI - CheckWMI can check various file and disk related things. The current version has commands to check Size of hard drives and directories.
CheckWMI = 1
; NRPE server - A simple server that listens for incoming NRPE connection and handles them. NRPE is preferred over NSClient as it is more flexible. You can of cource use both NSClient and NRPE.
NRPEServer = 1
; NSClient server - A simple server that listens for incoming NSClient (check_nt) connection and handles them. Although NRPE is the preferred method NSClient is fully supported and can be used for simplicity or for compatibility.
NSClientServer = 1
[/settings/default]
; ALLOWED HOSTS - A comaseparated list of allowed hosts. You can use netmasks (/ syntax) or * to create ranges.
allowed hosts = 192.168.100.xxx
; Section for NSClient (NSClientServer.dll) (check_nt) protocol options.
[/settings/NSClient/server]
; Section for system checks and system settings
[/settings/check/system/windows]
; Confiure which services has to be in which state
[/settings/check/system/windows/service mapping]
; Configure crash handling properties.
[/settings/crash]
; Section for the EventLog Checker (CheckEventLog.dll).
[/settings/eventlog]
; A set of options to configure the real time checks
[/settings/eventlog/real-time]
; A set of filters to use in real-time mode
[/settings/eventlog/real-time/filters]
; Section for external scripts configuration options (CheckExternalScripts).
[/settings/external scripts]
; A list of aliases available. An alias is an internal command that has been "wrapped" (to add arguments). Be careful so you don't create loops (ie check_loop=check_a, check_a=check_loop)
[/settings/external scripts/alias]
; A list of scripts available to run from the CheckExternalScripts module. Syntax is: <command>=<script> <arguments>
check_updates=cmd /c echo scripts\Check-Updates.ps1; exit $LastExitCode | powershell.exe -command -
; A list of wrappped scripts (ie. using the template mechanism)
; A list of templates for wrapped scripts
[/settings/external scripts/wrappings]
; Section for configuring the log handling.
[/settings/log]
; Configure log file properties.
[/settings/log/file]
; Section for configuring the shared session.
[/settings/shared session]
; A list of avalible remote target systems
[/settings/targets]
; Section for NRPE (NRPEListener.dll) (check_nrpe) protocol options.
[/settings/NRPE/server]
Thanks so much,
Tom
Tom
