When I try to download the "Bulk Import Wizard" the webpage asks me to login and then takes me to a page to purchase training support.
I have a valid support subcription.
Sal
unable to download plugins
lcontreras
Re: unable to download plugins
Hi Sal,
Which version of Nagios XI do you use?
Have you read this howto: http://assets.nagios.com/downloads/nagi ... Wizard.pdf ?
If download redirects you to login in, try with username and password for downloading.
New versions of Nagios XI has the plugin included.
regards,
regards,
That wizard is also included in both standard/enterprise edition installations, so you should not need to re-download it unless you had manually removed it. You can see if it is installed by checking Configure > CCM > Wizard > Bulk Host Cloning / Import.
