Can't detect all disk
pianunix
Post by pianunix »
Today i was trying to detect all the disk drive using plugin check_usolved_disks,
./check_usolved_disks -H localhost -C public -w 90 -c 95
./check_usolved_disks: line 6: syntax error near unexpected token `newline'
./check_usolved_disks: line 6: `<!DOCTYPE html>'
ref: http://exchange.nagios.org/directory/Pl ... ks/details
Please give me a clue for this ?
Thanks.
Re: Can't detect all disk
Post by Box293 »
It's more than likely that you've copied and pasted the plugin from the website and have included the HTML content.
From this URL:
https://github.com/usolved/check_usolve ... _disks.php
I was able to select all the text on screen, copy it and paste it into a file and then upload that file to my nagios host and it worked OK.
pianunix
Post by pianunix »
HI,
I've tried to, but still no get results
./check_usolved_disks.php -H localhost -C public -V 2 -w 90 -c 95 _P yes
:/usr/lib/nagios/plugins#
Another solution about this ?
Thx
Post by Box293 »
Please upload the plugin here (check_usolved_disks.php), rename it as a text file first.
pianunix
Post by pianunix »
Here is my configuration file
check_usolved.txt
(13.75 KiB) Downloaded 294 times
Try running this:
./check_usolved_disks.php -H localhost -C public -V 2c -w 90 -c 95 -P
Also, check if snmpd is running:
service snmpd status
pianunix
Post by pianunix »
^ Nothing happen.
Fyi i'm using debian squeeze on the server right know.
sreinhardt
-fno-stack-protector
Post by sreinhardt »
Are you able to query snmp locally?
nmap -sU -p 162 localhost
pianunix
Post by pianunix »
Yes we can,
Starting Nmap 5.00 ( http://nmap.org ) at 2014-08-04 10:39
Interesting ports on localhost (127.0.0.1):
PORT    STATE  SERVICE
162/udp closed snmptrap
Nmap done: 1 IP address (1 host up) scanned in 0.24 seconds
I believe that was supposed to be port 161:
nmap -sU -p 161 localhost
Sorry for the confusion. And what was the output of this command?
