CGI authori
Re: CGI authori
How are you accessing the CGI in this case? Is it by the command line or a direct call through the web browser?
In either case, please show the URL/string you are using to run the command.
Re: CGI authori
You are missing some required fields. This is the command that worked for me:
curl -d "cmd_typ=85&cmd_mod=2&hostgroup=linux-servers&com_data=SomeComment&start_time=07-28-2014+09%3A17%3A46&end_time=07-28-2014+11%3A17%3A46&fixed=1&hours=2&minutes=0&btnSubmit=Commit" 127.0.0.1/nagios/cgi-bin/cmd.cgi -u nagiosadmin:password
Try the equivalent on your system and let us know how it works out.
Re: CGI authori
We have a page detailing the different commands you can write directly to the nagios.cmd file (essentially a list of commands it needs to execute), but nothing like that for the CGIs specifically:
http://old.nagios.org/developerinfo/ext ... ndlist.php
If you are running this on the Nagios machine itself I would recommend using the nagios.cmd file, since the CGIs essentially write directly to that.
