2014R1.2 CCM Stuck in German
dangladesh
Post by dangladesh »
Somehow my Nagios CCM 1.03 is stuck in German.
Any support I've found directs a user to Config Manager Admin -> Config Manager Settings, but the language option is only available in the Legacy CCM (changing it there does not affect CCM 1.03).
Any help would be greatly appreciated.
abrist
Red Shirt
Re: 2014R1.2 CCM Stuck in German
Post by abrist »
Lets check your user in the ccm and see what language is set:
echo "select id,username,locale from nagiosql.tbl_user;" | mysql -t -pnagiosxi
dangladesh
Wunderbar, danke!!
This select revealed that the user locale was set to de_DE. I was able to change it with the following:
echo "update nagiosql.tbl_user set locale='en_EN' where username='<username>';" | mysql -t -pnagiosxi
I wonder how it ever got set to German in the first place.
dangladesh
Unfortunately, after logging out, rebooting the nagios machine, and logging back into CCM, it is still in German.
Do I have to apply a configuration or something like that?
abrist
Red Shirt
Post by abrist »
That query doesn't fix anything. I wanted to see the output to try to determine if the ccm was pulling the lang from the table . . . .
dangladesh
Okay. 'locale' was set to 'de_DE'
But I don't think that it is pulling the language from the table, because now 'locale' is set to 'en_EN' for the user.
dangladesh
Are there other places I could look for language configuration? Where can I go from here?
dangladesh
After updating the locale field in the tmp_user table to en_EN, the CCM did not recognize this change (even after a cache clear, reboot of nagios server, etc). After "Updating Credentials" (via a password reset) for the user, the CCM displayed the proper language. I am wondering if this change caused the CCM to look at the settings in the table that would have otherwise been stored somewhere else?
This seems to have solved my problem.
abrist
Red Shirt
Post by abrist »
It may have been a mismatch between the CCM locale in the nagiosql mysql db table and the postgresql user settings. (As both are updated when you change locales)
I am glad that it is fixed. When I get time I will investigate the tables a bit more to try to reproduce the behavior. Cheers!
