Can I extend the space of NSTI web interface?
phyo
Post by phyo »
Dear all,
I used NSTI to trace back all the SNMP Traps in my Nagios. But we can't see all the information in the NSTI web interface. Please see the picture.
https://db.tt/epn7qqd7
In the message column, we can't see all the information for each SNMP Traps. Is there a way to see all these information?
If relating to NSTI question can't ask here, feel free to delete my post.
Thanks.
sreinhardt
-fno-stack-protector
Re: Can I extend the space of NSTI web interface?
Post by sreinhardt »
Since we don't currently have an nsti customer forum, this is just fine. Which version of nsti are you presently running, it should say in the upper right or left hand corner.
phyo
Post by phyo »
sreinhardt wrote:Since we don't currently have an nsti customer forum, this is just fine. Which version of nsti are you presently running, it should say in the upper right or left hand corner.
Currently I am using NSTI RC1.4
Thanks.
sreinhardt
OK I think the very first thing we should do, is get you moved onto NSTI 3.0.x. There have been some massive reworkings that I know you will appreciate. I will go check with the developer on the state of the upgrade script, I know that's all he has left from 1.4 and its only small portions of that.
