Hi Support,
It seems like the new High performance switch wizard doesnt seem to detect 10gb interface.
Can you help me in finding out why.
Many Thanks
Arnab
Support for 10Gb Ethernet monitoring on High performance
Re: Support for 10Gb Ethernet monitoring on High performance
I assume you are talking about the "Network Switch / Router" wizard? What is the version that you see when you go to Admin->Manage Config Wizards? What are the errors that you are getting (screenshots, logs, etc.)?
