Haven't seen anything really posted about this yet, so I figured I'd ask about it here.
We run Nagios in our environment, and have our Windows and Linux servers reporting to it. It's been working great for us.
A few weeks ago, our weekly internal Nessus scans started flagging our Windows servers as having an open security hole. The exact report detail is:
Vulnerability found on port netsaint (5666/tcp) :
Synopsis :
The remote host is affected by a vulnerability that could allow
sensitive data to be decrypted.
Description :
The OpenSSL service on the remote host is vulnerable to a
man-in-the-middle (MiTM) attack, based on its response to two
consecutive 'ChangeCipherSpec' messages during the incorrect phase of
an SSL/TLS handshake.
This flaw could allow a MiTM attacker to decrypt or forge SSL messages
by telling the service to begin encrypted communications before key
material has been exchanged, which causes predictable keys to be used
to secure future traffic.
Note that Nessus has only tested for an SSL/TLS MiTM vulnerability
(CVE-2014-0224). However, Nessus has inferred that the OpenSSL service
on the remote host is also affected by six additional vulnerabilities
that were disclosed in OpenSSL's June 5th, 2014 security advisory :
- An error exists in the function 'ssl3_read_bytes'
that could allow data to be injected into other
sessions or allow denial of service attacks. Note
this issue is only exploitable if
'SSL_MODE_RELEASE_BUFFERS' is enabled. (CVE-2010-5298)
- An error exists related to the implementation of the
Elliptic Curve Digital Signature Algorithm (ECDSA) that
could allow nonce disclosure via the 'FLUSH+RELOAD'
cache side-channel attack. (CVE-2014-0076)
- A buffer overflow error exists related to invalid DTLS
fragment handling that could lead to execution of
arbitrary code. Note this issue only affects OpenSSL
when used as a DTLS client or server. (CVE-2014-0195)
- An error exists in the function 'do_ssl3_write' that
could allow a null pointer to be dereferenced leading
to denial of service attacks. Note this issue is
exploitable only if 'SSL_MODE_RELEASE_BUFFERS' is
enabled. (CVE-2014-0198)
- An error exists related to DTLS handshake handling that
could lead to denial of service attacks. Note this
issue only affects OpenSSL when used as a DTLS client.
(CVE-2014-0221)
- An unspecified error exists related to anonymous ECDH
ciphersuites that could allow denial of service
attacks. Note this issue only affects OpenSSL TLS
clients. (CVE-2014-3470)
OpenSSL did not release individual patches for these vulnerabilities,
instead they were all patched under a single version release. Note
that the service will remain vulnerable after patching until the
service or host is restarted.
See also :
http://www.nessus.org/u?d5709faa
https://www.imperialviolet.org/2014/06/05/earlyccs.html
https://www.openssl.org/news/secadv_20140605.txt
Solution :
OpenSSL 0.9.8 SSL/TLS users (client and/or server) should upgrade to
0.9.8za. OpenSSL 1.0.0 SSL/TLS users (client and/or server) should
upgrade to 1.0.0m. OpenSSL 1.0.1 SSL/TLS users (client and/or server)
should upgrade to 1.0.1h.
Risk factor :
High / CVSS Base Score : 9.3
(CVSS2#AV:N/AC:M/Au:N/C:C/I:C/A:C)
CVSS Temporal Score : 8.1
(CVSS2#E:ND/RL:OF/RC:C)
Public Exploit Available : true
Plugin output :
The remote service accepted an SSL ChangeCipherSpec message at an incorrect
point in the handshake
leading to weak keys being used, and then attempted to decrypt an SSL record
using those weak keys.
CVE : CVE-2010-5298, CVE-2014-0076, CVE-2014-0195, CVE-2014-0198,
CVE-2014-0221, CVE-2014-0224, CVE-2014-3470
BID : 66363, 66801, 67193, 67898, 67899, 67900, 67901
Other references : OSVDB:104810, OSVDB:105763, OSVDB:106531, OSVDB:107729,
OSVDB:107730, OSVDB:107731, OSVDB:107732, CERT:978508, IAVA:2014-A-0083When these systems were installed, they all used the agent that the Nagios system linked to during the monitoring wizard setup process. That link still points to http://assets.nagios.com/downloads/nagi ... SClient++/. The agents on that page are all from 2012, and appear to run version 0.3.9. It also looks like version 0.4.1 is the current version on the nsclient.org site, but I've heard that it's not nearly as stable. I also don't see anything that mentions that it actually addresses the vulnerability listed from the Nessus scans (they were announced on June 5th).
I'm wondering what everyone else is doing to mitigate this. Does the 0.4.1 address this issue? Any advice would really be appreciated.
