Change notification options globally?
akepley
Post by akepley »
I need to change the persistant notifications from every 60 seconds to 0 (Send one notification) for all services and hosts. that's almost 2,000 separate hosts/services. Is there a way to change many or all at once?
Re: Change notification options globally?
There's a feature in the Enterprise Edition called Bulk Modifications that will do just that. You can start a free 60-day trial, fully featured if you are interested.
The tool is located under the CCM, in the Tools sidebar section. In the tool click "Change A Single Config Option" and select the notification_interval from the dropdown.
akepley
Post by akepley »
Ah! I believe we are about to upgrade to Enterprise during our renewal (August) so this would be perfect. Thanks!
455157
Post by 455157 »
There should be a 60 day trial of Enterprise built-in as well, in the Admin -> License Information menu, if you want to start using it early :)
