Ok, so using the bulk host cloning wizard like I have many many times before.
I select the host and then all services, paste the csv, hit next then finish. The new hosts are created as well as all the services. However, it fills nothing out for the check command and ARGs. None of them are filled out and the apply config fails.
Bulk Host Cloning wizard wigging out on me!
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
Re: Bulk Host Cloning wizard wigging out on me!
What type of host are you cloning? Can you post the config of the host, that you use as a "template" for the bulk host cloning wizard?
Host:
Services:
More Testing - It is something on the services that is doing it. I can copy another host and services. I can also copy this host with no service. Still investigating
define host {
host_name CDM Checks - Linux
use generic-host
alias Template for new linux sevrers
address localhost
register 1
service_description CPU
check_command check_by_ssh_cpu!90,70,70!95,80,80!!!!!!
notification_interval 60
_xiwizard sshproxy
register 1
service_description Cron Scheduler
check_command check_by_ssh_init_service!crond!!!!!!!
_xiwizard sshproxy
register 1
service_description Disk
check_command check_by_ssh_disk!10%!5%!-e!!!!!
_xiwizard sshproxy
register 1
service_description Load
check_command check_by_ssh_load!35,30,25!43,38,33!!!!!!
_xiwizard sshproxy
register 1
service_description Log File
check_command check_by_ssh_log!/var/log/messages!Error!most_recent!!!!!
_xiwizard sshproxy
register 1
service_description Memory
check_command check_by_ssh_memory!10!5!!!!!!
_xiwizard sshproxy
register 1
service_description NFS
check_command check_by_ssh_nfs!!!!!!!!
_xiwizard sshproxy
register 1
service_description Read-Only File System
check_command check_by_ssh_rofs!!!!!!!!
_xiwizard sshproxy
register 1
service_description Swap
check_command check_by_ssh_swap!80%!70%!!!!!!
_xiwizard sshproxy
register 1
service_description Total Processes
check_command check_by_ssh_procs!2900!3200!!!!!!
_xiwizard sshproxy
register 1
service_description VNC 01
check_command check_vnc!01!!!!!!!
_xiwizard sshproxy
register 1
service_description Zombie Processes
check_command check_by_ssh_procs!5!10!-s Z!!!!!
_xiwizard sshproxy
register 1
Bandit,
I had a similar issue with the bulk host cloning wizard. Seems it had also something to do with one service that was connected to a source host. After recreating this source host with it's services, it worked normally again.
Grtz
Grtz
Nagios XI 5.8.1
https://outsideit.net
Thanks Willem. I just deleted the host as I had it setup just for a template and then re-wrote the directions for my team to use a different "real" host. I spent nearly all day yesterday trying to troubleshoot this to find the root cause and just couldn't. I made it identical to other hosts that I could copy and nothing, just nuts!
As I am typing this, I do recall, I used the renaming tool on the host, I wonder if that was the cause of the issue! Someone at nagios should test that
Feel free to lock this up!
Impossible! We never make mistakes!BanditBBS wrote:As I am typing this, I do recall, I used the renaming tool on the host, I wonder if that was the cause of the issue! Someone at nagios should test that :)
I'll take a look. Closing thread now.
