Hello.
Some of our graphics, using nagios grapher (1.7.1) is just not graphing some services in some hosts (the graph is working for the same service in other hosts) and some of them are just showing a lot of gaps.
What can be causing this and how to diagnose it?!
nagios_grapher failing and showing a lot of gaps
- Box293
- Too Basu
Re: nagios_grapher failing and showing a lot of gaps
It's best you contact the developer of this project to diagnose these problems.
Perhaps see what's in the httpd error log:
Or you could use rrdtool with the fetch argument to see if the .rrd files actually contain data.
tail /var/log/httpd/error_logAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
RDD is being updated.
We have the following errors in /var/log/httpd/error.log
Aug 01 11:56:43 2014] [error] [client ] [Fri Aug 1 11:56:43 2014] graphs.cgi: Argument "-1w" isn't numeric in multiplication (*) at /usr/lib64/nagios/cgi-bin/graphs.cgi line 479, <CGI> line 366.
[Fri Aug 01 11:56:43 2014] [error] [client ] [Fri Aug 1 11:56:43 2014] graphs.cgi: Argument "-1m" isn't numeric in multiplication (*) at /usr/lib64/nagios/cgi-bin/graphs.cgi line 479, <CGI> line 366.
[Fri Aug 01 11:56:43 2014] [error] [client ] [Fri Aug 1 11:56:43 2014] graphs.cgi: Argument "-1y" isn't numeric in multiplication (*) at /usr/lib64/nagios/cgi-bin/graphs.cgi line 479, <CGI> line 366.
[Fri Aug 01 11:56:48 2014] [error] [client ] Use of uninitialized value $upper_limit in numeric gt (>) at /usr/lib64/nagios/cgi-bin/rrd2-graph.cgi line 433., referer: http://xxx/nagios/cgi-bin//status.cgi?n ... 1&host=yyy
We are using the version 1.7.1.
Any idea?
Any idea?
sreinhardt
- -fno-stack-protector
As tlea suggested, we do not create nagios_grapher, and very minimally support it. I would highly suggest talking with the developer of the tool instead, as it looks like there is either a bug with your installation or with the version as a whole, it is impossible for me to know though.
Ok, thanks. I will try to find their forum.
