XI System Component Status & Nagiosxi issues
anil406
Post by anil406 »
Hello Support,
I am seeing below after the nagiosxi upgrade to latest, and also nagios service status shows its not running, while its actually running. On web interface some hosts gives the Host Status Detail when clicked from the dashboard while some take me to blank page..
Re: XI System Component Status & Nagiosxi issues
Let's make sure all of your critical services are running:
service crond status
service nagios status
service mysqld status
service ndo2db status
anil406
Post by anil406 »
thanks. crond, mysqld are running, but nagios and ndo2db are not running..
[root@nagios01 var]# service nagios status
nagios is not running
Nagios show its not running, however process has kicked off..
nagios 4666 1 3 10:41 ? 00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
[root@nagios01 var]# service ndo2db status
ndo2db is not running but subsystem locked
Run the following commands and show the output:
tail -20 /var/log/messages
/usr/local/nagios/bin/nagios | head -2
/usr/local/nagios/bin/ndo2db | head -2
anil406
Post by anil406 »
may i should have posted it here, as this is right ticket for nagiosxi issue..anyways,here we go.., I am seeing its unable to data sink due to ndo2db is not running, so i tried to start it, it unable to start due subsystem is locked, hence i removed the lock file and tried again, still wont start ..
[root@nagios01 init.d]# tail -20 /var/log/messages
Jul 31 15:15:23 nagios01 nagios: ndomod: Still unable to connect to data sink. 490948 items lost, 5000 queued items to flush.
Jul 31 15:21:12 nagios01 nagios: SERVICE ALERT: sprucegen016.load.ssn-silver.cb;TestTalk;CRITICAL;SOFT;1;CRITICAL - Plugin timed out after 10 seconds
Jul 31 15:22:06 nagios01 nagios: SERVICE ALERT: sprucegen016.load.ssn-silver.cb;TestTalk;OK;SOFT;2;OK
Jul 31 15:30:35 nagios01 nagios: ndomod: Still unable to connect to data sink. 518028 items lost, 5000 queued items to flush.
Jul 31 15:41:42 nagios01 nagios: Auto-save of retention data completed successfully.
Jul 31 15:45:47 nagios01 nagios: ndomod: Still unable to connect to data sink. 545139 items lost, 5000 queued items to flush.
Jul 31 15:52:12 nagios01 nagios: SERVICE ALERT: sprucegen016.load.ssn-silver.cb;TestTalk;CRITICAL;SOFT;1;CRITICAL - Plugin timed out after 10 seconds
Jul 31 15:53:08 nagios01 nagios: SERVICE ALERT: sprucegen016.load.ssn-silver.cb;TestTalk;OK;SOFT;2;OK
Jul 31 15:53:54 nagios01 nagios: HOST NOTIFICATION: nagiosadmin;container74-web-02.spruce.cb;DOWN;xi_host_notification_handler;check_icmp: Failed to resolve address
Jul 31 15:56:10 nagios01 nagios: SERVICE ALERT: soa-02.spruce.cb;/var usage;CRITICAL;SOFT;1;CRITICAL - Plugin timed out after 10 seconds
Jul 31 15:57:00 nagios01 nagios: SERVICE ALERT: soa-02.spruce.cb;/var usage;OK;SOFT;2;DISK OK - free space: /var 2629 MB (69% inode=99%):
Jul 31 15:58:24 nagios01 nagios: HOST NOTIFICATION: nagiosadmin;container74-web-01.spruce.cb;DOWN;xi_host_notification_handler;check_icmp: Failed to resolve address
Jul 31 16:00:36 nagios01 nagios: SERVICE NOTIFICATION: nagiosadmin;cid1-instance.spruce.cb;Total Processes;WARNING;xi_service_notification_handler;PROCS WARNING: 162 processes
Jul 31 16:00:59 nagios01 nagios: ndomod: Still unable to connect to data sink. 572248 items lost, 5000 queued items to flush.
Jul 31 16:13:31 nagios01 nagios: ndomod: Successfully connected to data sink. 594224 items lost, 5000 queued items to flush.
Jul 31 16:13:31 nagios01 nagios: ndomod: Successfully flushed 5000 queued items to data sink.
Jul 31 16:20:12 nagios01 nagios: SERVICE ALERT: sprucegen036.load.ssn-silver.cb;TestTalk;CRITICAL;SOFT;1;CRITICAL - Plugin timed out after 10 seconds
Jul 31 16:21:07 nagios01 nagios: SERVICE ALERT: sprucegen036.load.ssn-silver.cb;TestTalk;OK;SOFT;2;OK
Jul 31 16:27:11 nagios01 nagios: SERVICE ALERT: sprucegen001.load.ssn-silver.cb;Current Load;CRITICAL;SOFT;1;CRITICAL - Plugin timed out after 10 seconds
Jul 31 16:28:07 nagios01 nagios: SERVICE ALERT: sprucegen001.load.ssn-silver.cb;Current Load;OK;SOFT;2;OK - load average: 0.00, 0.00, 0.00
[root@nagios01 init.d]#/usr/local/nagios/bin/nagios | head -2;/usr/local/nagios/bin/ndo2db |head -2
Nagios Core 4.0.7
NDO2DB 2.0.0
Can you post the output of the following
chage -l nagios
tail /var/log/cron
anil406
Post by anil406 »
Scott, we are using ldap id(nagios). I am posting the tail of cron log..
Aug 1 12:36:01 nagios01 CROND[29101]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cleaner.php > /usr/local/nagiosxi/var/cleaner.log 2>&1)
Aug 1 12:36:01 nagios01 CROND[29104]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/reportengine.php > /usr/local/nagiosxi/var/reportengine.log 2>&1)
Aug 1 12:37:01 nagios01 CROND[29235]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/nom.php > /usr/local/nagiosxi/var/nom.log 2>&1)
Aug 1 12:37:01 nagios01 CROND[29236]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cleaner.php > /usr/local/nagiosxi/var/cleaner.log 2>&1)
Aug 1 12:37:01 nagios01 CROND[29237]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/reportengine.php > /usr/local/nagiosxi/var/reportengine.log 2>&1)
Aug 1 12:37:01 nagios01 CROND[29242]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/eventman.php > /usr/local/nagiosxi/var/eventman.log 2>&1)
Aug 1 12:37:01 nagios01 CROND[29244]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/perfdataproc.php > /usr/local/nagiosxi/var/perfdataproc.log 2>&1)
Aug 1 12:37:01 nagios01 CROND[29240]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/feedproc.php > /usr/local/nagiosxi/var/feedproc.log 2>&1)
Aug 1 12:37:01 nagios01 CROND[29243]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/sysstat.php > /usr/local/nagiosxi/var/sysstat.log 2>&1)
Aug 1 12:37:01 nagios01 CROND[29245]: (nagios) CMD (/usr/bin/php -q /usr/local/nagiosxi/cron/cmdsubsys.php > /usr/local/nagiosxi/var/cmdsubsys.log 2>&1)
Can you post the nagios.cfg file?
anil406
Post by anil406 »
[root@nagios01 etc]# more nagios.cfg
# MODIFIED
admin_email=root@localhost
admin_pager=root@localhost
translate_passive_host_checks=1
log_event_handlers=0
use_large_installation_tweaks=1
enable_environment_macros=0
# NDOUtils module
broker_module=/usr/local/nagios/bin/ndomod.o config_file=/usr/local/nagios/etc/ndomod.cfg
# PNP settings - bulk mode with NCPD
process_performance_data=1
# service performance data
service_perfdata_file=/usr/local/nagios/var/service-perfdata
service_perfdata_file_template=DATATYPE::SERVICEPERFDATA\tTIMET::$TIMET$\tHOSTNAME::$HOSTNAME$\tSERVICEDESC::$SERVICEDESC$\tSERVICEPERFDATA::$SERVICEPERFDATA
$\tSERVICECHECKCOMMAND::$SERVICECHECKCOMMAND$\tHOSTSTATE::$HOSTSTATE$\tHOSTSTATETYPE::$HOSTSTATETYPE$\tSERVICESTATE::$SERVICESTATE$\tSERVICESTATETYPE::$SERVI
CESTATETYPE$\tSERVICEOUTPUT::$SERVICEOUTPUT$
service_perfdata_file_mode=a
service_perfdata_file_processing_interval=15
service_perfdata_file_processing_command=process-service-perfdata-file-bulk
# host performance data
host_perfdata_file=/usr/local/nagios/var/host-perfdata
host_perfdata_file_template=DATATYPE::HOSTPERFDATA\tTIMET::$TIMET$\tHOSTNAME::$HOSTNAME$\tHOSTPERFDATA::$HOSTPERFDATA$\tHOSTCHECKCOMMAND::$HOSTCHECKCOMMAND$\
tHOSTSTATE::$HOSTSTATE$\tHOSTSTATETYPE::$HOSTSTATETYPE$\tHOSTOUTPUT::$HOSTOUTPUT$
host_perfdata_file_mode=a
host_perfdata_file_processing_interval=15
host_perfdata_file_processing_command=process-host-perfdata-file-bulk
# OBJECTS - UNMODIFIED
#cfg_file=/usr/local/nagios/etc/objects/commands.cfg
#cfg_file=/usr/local/nagios/etc/objects/contacts.cfg
#cfg_file=/usr/local/nagios/etc/objects/localhost.cfg
#cfg_file=/usr/local/nagios/etc/objects/templates.cfg
#cfg_file=/usr/local/nagios/etc/objects/timeperiods.cfg
# STATIC OBJECT DEFINITIONS (THESE DON'T GET EXPORTED/IMPORTED BY NAGIOSQL)
cfg_dir=/usr/local/nagios/etc/static
# OBJECTS EXPORTED FROM NAGIOSQL
cfg_file=/usr/local/nagios/etc/contacttemplates.cfg
cfg_file=/usr/local/nagios/etc/contactgroups.cfg
cfg_file=/usr/local/nagios/etc/contacts.cfg
cfg_file=/usr/local/nagios/etc/timeperiods.cfg
cfg_file=/usr/local/nagios/etc/commands.cfg
cfg_file=/usr/local/nagios/etc/hostgroups.cfg
cfg_file=/usr/local/nagios/etc/servicegroups.cfg
cfg_file=/usr/local/nagios/etc/hosttemplates.cfg
cfg_file=/usr/local/nagios/etc/servicetemplates.cfg
cfg_file=/usr/local/nagios/etc/servicedependencies.cfg
cfg_file=/usr/local/nagios/etc/serviceescalations.cfg
cfg_file=/usr/local/nagios/etc/hostdependencies.cfg
cfg_file=/usr/local/nagios/etc/hostescalations.cfg
cfg_file=/usr/local/nagios/etc/hostextinfo.cfg
cfg_file=/usr/local/nagios/etc/serviceextinfo.cfg
[root@nagios01 etc]# ls /usr/local/nagios/bin/
file2sock   log2ndo     nagios      nagiostats  ndo2db      ndomod.o    npcd        npcdmod.o   nrpe        nsca        sockdebug
# MODIFIED
# NDOUtils module
cfg_dir=/usr/local/nagios/etc/hosts
cfg_dir=/usr/local/nagios/etc/services
# GLOBAL EVENT HANDLERS
global_host_event_handler=xi_host_event_handler
global_service_event_handler=xi_service_event_handler
# UNMODIFIED
accept_passive_host_checks=1
additional_freshness_latency=15
auto_reschedule_checks=0
auto_rescheduling_interval=30
auto_rescheduling_window=180
bare_update_check=0
cached_host_check_horizon=15
cached_service_check_horizon=15
check_external_commands=1
check_for_orphaned_hosts=1
check_for_orphaned_services=1
check_for_updates=1
check_host_freshness=0
check_result_path=/usr/local/nagios/var/spool/checkresults
check_service_freshness=1
command_check_interval=-1
command_file=/usr/local/nagios/var/rw/nagios.cmd
daemon_dumps_core=0
date_format=us
debug_file=/usr/local/nagios/var/nagios.debug
debug_level=0
debug_verbosity=1
enable_embedded_perl=1
enable_event_handlers=1
enable_flap_detection=1
enable_notifications=1
event_broker_options=-1
event_handler_timeout=30
execute_host_checks=1
execute_service_checks=1
external_command_buffer_slots=4096
high_host_flap_threshold=20.0
host_check_timeout=30
interval_length=60
lock_file=/usr/local/nagios/var/nagios.lock
log_external_commands=0
log_file=/usr/local/nagios/var/nagios.log
log_host_retries=1
log_initial_states=0
anil406
Post by anil406 »
Hello lmitchev,
I think ndo2db binary isnt updating the ndo2db lock with pid, as you can see lock files are empty even though service is up. Same happens with nagios too...Here is what i found..
[root@nagios01 bin]# bash -x /etc/init.d/ndo2db status
+ '[' -f /etc/rc.d/init.d/functions ']'
+ . /etc/rc.d/init.d/functions
++ TEXTDOMAIN=initscripts
++ umask 022
++ PATH=/sbin:/usr/sbin:/bin:/usr/bin
++ export PATH
++ '[' -z '' ']'
++ COLUMNS=80
++ '[' -z '' ']'
+++ /sbin/consoletype
++ CONSOLETYPE=pty
++ '[' -f /etc/sysconfig/i18n -a -z '' -a -z '' ']'
++ . /etc/profile.d/lang.sh
++ unset LANGSH_SOURCED
++ '[' -z '' ']'
++ '[' -f /etc/sysconfig/init ']'
++ . /etc/sysconfig/init
+++ BOOTUP=color
+++ RES_COL=60
+++ MOVE_TO_COL='echo -en \033[60G'
+++ SETCOLOR_SUCCESS='echo -en \033[0;32m'
+++ SETCOLOR_FAILURE='echo -en \033[0;31m'
+++ SETCOLOR_WARNING='echo -en \033[0;33m'
+++ SETCOLOR_NORMAL='echo -en \033[0;39m'
+++ PROMPT=yes
+++ AUTOSWAP=no
+++ ACTIVE_CONSOLES='/dev/tty[1-6]'
+++ SINGLE=/sbin/sushell
++ '[' pty = serial ']'
++ __sed_discard_ignored_files='/\(~\|\.bak\|\.orig\|\.rpmnew\|\.rpmorig\|\.rpmsave\)$/d'
+ servicename=ndo2db
+ prefix=/usr/local/nagios
+ exec_prefix=/usr/local/nagios
+ Ndo2dbBin=/usr/local/nagios/bin/ndo2db
+ Ndo2dbCfgFile=/usr/local/nagios/etc/ndo2db.cfg
+ Ndo2dbVarDir=/usr/local/nagios/var
+ Ndo2dbRunFile=/usr/local/nagios/var/ndo2db.lock
+ Ndo2dbLockDir=/usr/local/nagiosxi/var/subsys
+ Ndo2dbLockFile=ndo2db
+ Ndo2dbUser=nagios
+ Ndo2dbGroup=nagios
+ '[' '!' -f /usr/local/nagios/bin/ndo2db ']'
+ '[' '!' -f /usr/local/nagios/etc/ndo2db.cfg ']'
+ case "$1" in
+ printstatus_ndo2db
+ status_ndo2db
+ pid_ndo2db
+ test '!' -f /usr/local/nagios/var/ndo2db.lock
++ head -n 1 /usr/local/nagios/var/ndo2db.lock
+ Ndo2dbPID=
+ return 0
+ ps -p
+ test -f /usr/local/nagiosxi/var/subsys/ndo2db
+ return 2
+ test 2 == 2
+ echo 'ndo2db is not running but subsystem locked'
+ exit 1
[root@nagios01 bin]# ps -ef | grep ndo2db
nagios 19643 1 0 14:39 ? 00:00:00 /usr/local/nagios/bin/ndo2db -c /usr/local/nagios/etc/ndo2db.cfg
nagios 19763 19643 0 14:39 ? 00:00:00 /usr/local/nagios/bin/ndo2db -c /usr/local/nagios/etc/ndo2db.cfg
nagios 19764 19763 1 14:39 ? 00:00:04 /usr/local/nagios/bin/ndo2db -c /usr/local/nagios/etc/ndo2db.cfg
root 31771 635 0 14:45 pts/0 00:00:00 grep ndo2db
[root@nagios01 bin]# ls -l /usr/local/nagios/var/ndo2db.lock
-rw-r--r-- 1 nagios nagios 0 Aug 1 14:39 /usr/local/nagios/var/ndo2db.lock
