Solaris 10 nrpe problems
We are trying to install nrpe in a Solaris 10 machine:
SunOS pnms 5.10 Generic_120011-14 sun4u sparc SUNW,Sun-Fire-280R
I am able to install successfully the NRPE agent, when I run:
bash-3.00# netstat -an | grep 5666
*.5666 *.* 0 0 49152 0 LISTEN
Also Running:
bash-3.00# /usr/local/nagios/libexec/check_nrpe -H localhost
NRPE v2.12
seems proper.
I have added the host via the configuration wizard in Nagios XI and all services, except ping, return errors. Other commands seem to have not been defined, while in the /var/adm/messages I get the following for example:
Jul 31 14:25:02 pnms nrpe[19741]: [ID 900267 daemon.error] Client request was invalid, bailing out...
Jul 31 14:29:52 pnms nrpe[19752]: [ID 441885 daemon.error] Error: Request contained command arguments!
Jul 31 14:29:52 pnms nrpe[19752]: [ID 900267 daemon.error] Client request was invalid, bailing out...
Jul 31 15:05:02 pnms nrpe[9312]: [ID 396531 daemon.error] Error: Request contained command arguments, but argument option is not enabled!
Jul 31 15:05:02 pnms nrpe[9312]: [ID 900267 daemon.error] Client request was invalid, bailing out...
Jul 31 15:07:21 pnms nrpe[9319]: [ID 813741 daemon.error] Error: Could not complete SSL handshake. 5
Jul 31 15:08:05 pnms nrpe[9326]: [ID 813741 daemon.error] Error: Could not complete SSL handshake. 5
Jul 31 15:09:31 pnms nrpe[9327]: [ID 813741 daemon.error] Error: Could not complete SSL handshake. 5
Jul 31 15:15:22 pnms nrpe[9361]: [ID 813741 daemon.error] Error: Could not complete SSL handshake. 5
Jul 31 15:34:26 pnms nrpe[9463]: [ID 813741 daemon.error] Error: Could not complete SSL handshake. 5
We are really new to this, we bought Nagios XI and we are struggling with the Solaris Monitoring. Can you please provide some help?
Thank you in advance
Also Running:
NRPE v2.12
seems proper.
Re: Solaris 10 nrpe problems
Did you compile NRPE with the --enable-command-args flag?
http://www.thegeekstuff.com/2010/12/ena ... arguments/
You would also need to set dont_blame_nrpe=1 in the configs. That would explain the errors if you are trying to pass arguments to the commands.
Yes, I have done both. Still I get the same errors. Please advise.
sreinhardt
- -fno-stack-protector
What version of openssl do you have on the client and servers? (nagios and solaris)
Server:
OpenSSL 1.0.1e-fips 11 Feb 2013
Client:
OpenSSL 0.9.7d 17 Mar 2004 (+ security patches to 2006-09-29)
Client:
I have over 300 Solaris instances running every version under the sky using nrpe without issues. Maybe I can assist you on this.bkoutsob wrote:Yes, I have done both. Still I get the same errors. Please advise.
What version of Solaris are you using? x86 or SPARC?
What release version is the OS?
What is the command line used to start the agent?
I am using nohup /usr/local/nagios/bin/nrpe -c /usr/local/nagios/etc/nrpe.cfg -d. Not using the xinetd.
If you still cannot solve it, I can pass you my nrpe 2.15 compiled with enable arguments?
5 x Nagios 5.6.9 Enterprise Edition
RHEL 6 & 7
rrdcached & ramdisk optimisation
RHEL 6 & 7
My version is Sparc
Running as:
nrpe stream tcp nowait nagios /usr/sfw/sbin/tcpd /usr/local/nagios/bin/nrpe \ -c /usr/local/nagios/etc/nrpe.cfg -i
can you upload the compiled version you have somewhere for me to get it? it might work. thank you!
Running as:
Using the command you send me it seems to work better, however I am getting for example:
OUTPUT: NRPE: Command 'check_mem' not defined
also for example:
COMMAND: /usr/local/nagios/libexec/check_nrpe -H 10.10.33.15 -t 30 -c check_disk -a '-w 20% -c 10% -p /'
OUTPUT: DISK CRITICAL - 20% is not accessible: No such file or directory
COMMAND: /usr/local/nagios/libexec/check_nrpe -H 10.10.33.15 -t 30 -c check_all_procs -a '-w 150 -c 250'
OUTPUT: NRPE: Command 'check_all_procs' not defined
long story short, none of the services installed by the wizard work. do I have to define each and every command? do you by any chance have a .cfg file with most of the commands defined?
also for example:
This means it is working, however you need to define the command in the target server's nrpe.cfg.bkoutsob wrote:Using the command you send me it seems to work better, however I am getting for example:
also for example:
Guess what I don't use wizards, too much hassle to get it to work the way I want it to work and it is full of holes.
Add this in your nrpe.cfg and create your services manually. Ensure there are no duplicate commands. It will silently accept one of it.
command[check_disk]=/usr/local/nagios/libexec/check_disk -w $ARG1$ -c $ARG2$ -p $ARG3$ $ARG4$
command[check_disk_all]=/usr/local/nagios/libexec/check_disk -w $ARG1$ -c $ARG2$ -A
command[check_disk_all_gbl]=/usr/local/nagios/libexec/check_disk -w $ARG1$ -c $ARG2$ -A -i $ARG3$
command[check_procs]=/usr/local/nagios/libexec/check_procs -w $ARG1$ -c $ARG2$ -s $ARG3$ $ARG4$
command[check_users]=/usr/local/nagios/libexec/check_users -w $ARG1$ -c $ARG2$ $ARG3$
command[check_memory]=/usr/local/nagios/libexec/check_mem.pl -u -w $ARG1$ -c $ARG2$ $ARG3$
command[check_load]=/usr/local/nagios/libexec/check_load -w $ARG1$ -c $ARG2$ $ARG3$ -r
command[check_memory_used]=/usr/local/nagios/libexec/check_mem.pl -u -w $ARG1$ -c $ARG2$ $ARG3$
command[check_tcp]=/usr/local/nagios/libexec/check_tcp -H $ARG1$ -p $ARG2$ $ARG3$
RHEL 6 & 7
RHEL 6 & 7
Thank you for your help! If there is a list will many commands I will gladly use it as I need to test some services. Which means, as many as you have will be of use
