backups
Sbergonzi
backups
Post by Sbergonzi »
I'm doing research on backing up the system and have read through http://assets.nagios.com/downloads/nagi ... ios-XI.pdf.
I noticed in /store/backups there are daily/weekly/monthly backups as well. Are these backups done by default automatically and I should rsync this information to another server or should I use the script (backup_xi.sh) and just backup the single file produced?
thank you!
Re: backups
All you need is the *.tar.gz file in "/store/backups/nagiosxi/" directory. It's a full backup that you can actually transfer to a different server, and restore XI from it.
However, if you didn't run the backup script, you wouldn't have the *tar.gz file to restore from... :)
The daily/weekly/monthly backups are run automatically on a cron.
You can view the cron entries by running:
grep auto /etc/cron.d/nagiosxi
Sbergonzi
Re: backups
Post by Sbergonzi »
thank you, good to go!
