This isn't possible. The first line Nagios finds that isn't a proper nagios config line, it will error out and tell you the offending line is a misconfig.
You can use the $USERX$ macros for this, but they would all be in the one file.
Disregard this post, complete misunderstanding. @eloyd is correct here.
For instance, we define a "_SSH_PORT" custom object variable on each host because we run SSH on non-standard ports. We can then use this on a "check_ssh -p $_HOST_SSH_PORT" service check so that each host gets its custom SSH port checked without having to do something weird.
Your mileage may vary, but you can do a lot with the built-in macro capabilities.
I completely misread the initial post - I thought @badonde was asking how to pass variables into a service (like passing arguments to a function), implying the config files have their own scripting language!
