Could I have some help with the configuration and installation of the check_modbus plugin on a Nagios XI server. I've been trying for a few hours to get it working on my test Nagios server, but I keep running into errors. The device I need to get information from is a SOCOMEC MASTER Diris A40v3/A40R.
I tried quering the device with snmp, but this did not work. After consulting the supplier, they told us we need to use RS485 id. after searching the Nagios Exchange, I found the check_modbus plugin, which is the only one talking about RS485.
http://exchange.nagios.org/directory/Pl ... us/details
On GitHub, the changelog of the plugin mentioned update 0.47 solves a few problems with Nagios ranges, so I tried installing the plugin, following directions on http://leshcatlabs.net/2014/04/15/power ... th-nagios/
So I started with installing libmodbus:
[root@nagiosserver libmodbus-3.0.6]# ./configure;make;make install;
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether make supports nested variables... yes
checking whether make supports nested variables... (cached) yes
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking whether gcc understands -c and -o together... yes
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
checking whether make sets $(MAKE)... (cached) yes
checking how to print strings... printf
checking for a sed that does not truncate output... /bin/sed
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for fgrep... /bin/grep -F
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 1966080
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... yes
checking how to convert x86_64-unknown-linux-gnu file names to x86_64-unknown-linux-gnu format... func_convert_file_noop
checking how to convert x86_64-unknown-linux-gnu file names to toolchain format... func_convert_file_noop
checking for /usr/bin/ld option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... pass_all
checking for dlltool... no
checking how to associate runtime and link libraries... printf %s\n
checking for ar... ar
checking for archiver @FILE support... @
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for sysroot... no
checking for mt... no
checking if : is a manifest tool... no
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works... yes
checking if gcc static flag -static works... no
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... no
checking how to run the C++ preprocessor... g++ -E
checking for ld used by g++... /usr/bin/ld -m elf_x86_64
checking if the linker (/usr/bin/ld -m elf_x86_64) is GNU ld... yes
checking whether the g++ linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking for g++ option to produce PIC... -fPIC -DPIC
checking if g++ PIC flag -fPIC -DPIC works... yes
checking if g++ static flag -static works... no
checking if g++ supports -c -o file.o... yes
checking if g++ supports -c -o file.o... (cached) yes
checking dynamic linker characteristics... (cached) GNU/Linux ld.so
checking termios.h usability... yes
checking termios.h presence... yes
checking for termios.h... yes
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking time.h usability... yes
checking time.h presence... yes
checking for time.h... yes
checking for unistd.h... (cached) yes
checking errno.h usability... yes
checking errno.h presence... yes
checking for errno.h... yes
checking limits.h usability... yes
checking limits.h presence... yes
checking for limits.h... yes
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking for sys/types.h... (cached) yes
checking sys/socket.h usability... yes
checking sys/socket.h presence... yes
checking for sys/socket.h... yes
checking sys/ioctl.h usability... yes
checking sys/ioctl.h presence... yes
checking for sys/ioctl.h... yes
checking netinet/in.h usability... yes
checking netinet/in.h presence... yes
checking for netinet/in.h... yes
checking netinet/tcp.h usability... yes
checking netinet/tcp.h presence... yes
checking for netinet/tcp.h... yes
checking arpa/inet.h usability... yes
checking arpa/inet.h presence... yes
checking for arpa/inet.h... yes
checking netdb.h usability... yes
checking netdb.h presence... yes
checking for netdb.h... yes
checking linux/serial.h usability... yes
checking linux/serial.h presence... yes
checking for linux/serial.h... yes
checking for asciidoc... no
checking for xmlto... no
checking whether to build documentation... no
checking whether to install manpages... yes
checking for ANSI C header files... (cached) yes
checking for an ANSI C-conforming const... yes
checking for size_t... yes
checking whether time.h and sys/time.h may both be included... yes
checking whether __CYGWIN__ is declared... no
checking for pid_t... yes
checking vfork.h usability... no
checking vfork.h presence... no
checking for vfork.h... no
checking for fork... yes
checking for vfork... yes
checking for working fork... yes
checking for working vfork... (cached) yes
checking for gettimeofday... yes
checking for inet_ntoa... yes
checking for memset... yes
checking for select... yes
checking for socket... yes
checking for strerror... yes
checking for strlcpy... no
checking for getaddrinfo... yes
checking winsock2.h usability... no
checking winsock2.h presence... no
checking for winsock2.h... no
checking whether TIOCSRS485 is declared... yes
checking that generated files are newer than configure... done
configure: creating ./config.status
config.status: creating Makefile
config.status: creating src/Makefile
config.status: creating src/modbus-version.h
config.status: creating doc/Makefile
config.status: creating tests/Makefile
config.status: creating libmodbus.pc
config.status: creating libmodbus.spec
config.status: creating config.h
config.status: creating tests/unit-test.h
config.status: tests/unit-test.h is unchanged
config.status: executing depfiles commands
config.status: executing libtool commands
make all-recursive
make[1]: Entering directory `/usr/src/libmodbus-3.0.6'
Making all in src
make[2]: Entering directory `/usr/src/libmodbus-3.0.6/src'
CC modbus.lo
CC modbus-data.lo
CC modbus-rtu.lo
CC modbus-tcp.lo
CCLD libmodbus.la
make[2]: Leaving directory `/usr/src/libmodbus-3.0.6/src'
Making all in doc
make[2]: Entering directory `/usr/src/libmodbus-3.0.6/doc'
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory `/usr/src/libmodbus-3.0.6/doc'
Making all in tests
make[2]: Entering directory `/usr/src/libmodbus-3.0.6/tests'
make all-am
make[3]: Entering directory `/usr/src/libmodbus-3.0.6/tests'
CC bandwidth-server-one.o
CCLD bandwidth-server-one
CC bandwidth-server-many-up.o
CCLD bandwidth-server-many-up
CC bandwidth-client.o
CCLD bandwidth-client
CC random-test-server.o
CCLD random-test-server
CC random-test-client.o
CCLD random-test-client
CC unit-test-server.o
CCLD unit-test-server
CC unit-test-client.o
CCLD unit-test-client
CC version.o
CCLD version
make[3]: Leaving directory `/usr/src/libmodbus-3.0.6/tests'
make[2]: Leaving directory `/usr/src/libmodbus-3.0.6/tests'
make[2]: Entering directory `/usr/src/libmodbus-3.0.6'
make[2]: Leaving directory `/usr/src/libmodbus-3.0.6'
make[1]: Leaving directory `/usr/src/libmodbus-3.0.6'
Making install in src
make[1]: Entering directory `/usr/src/libmodbus-3.0.6/src'
/bin/mkdir -p '/usr/local/lib'
/bin/sh ../libtool --mode=install /usr/bin/install -c libmodbus.la '/usr/local/lib'
libtool: install: /usr/bin/install -c .libs/libmodbus.so.5.0.5 /usr/local/lib/libmodbus.so.5.0.5
libtool: install: (cd /usr/local/lib && { ln -s -f libmodbus.so.5.0.5 libmodbus.so.5 || { rm -f libmodbus.so.5 && ln -s libmodbus.so.5.0.5 libmodbus.so.5; }; })
libtool: install: (cd /usr/local/lib && { ln -s -f libmodbus.so.5.0.5 libmodbus.so || { rm -f libmodbus.so && ln -s libmodbus.so.5.0.5 libmodbus.so; }; })
libtool: install: /usr/bin/install -c .libs/libmodbus.lai /usr/local/lib/libmodbus.la
libtool: finish: PATH="/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin:/root/bin:/sbin" ldconfig -n /usr/local/lib
Libraries have been installed in:
/usr/local/lib
If you ever happen to want to link against installed libraries
in a given directory, LIBDIR, you must either use libtool, and
specify the full pathname of the library, or use the `-LLIBDIR'
flag during linking and do at least one of the following:
- add LIBDIR to the `LD_LIBRARY_PATH' environment variable
during execution
- add LIBDIR to the `LD_RUN_PATH' environment variable
during linking
- use the `-Wl,-rpath -Wl,LIBDIR' linker flag
- have your system administrator add LIBDIR to `/etc/ld.so.conf'
See any operating system documentation about shared libraries for
more information, such as the ld(1) and ld.so(8) manual pages.
/bin/mkdir -p '/usr/local/include/modbus'
/usr/bin/install -c -m 644 modbus.h modbus-version.h modbus-rtu.h modbus-tcp.h '/usr/local/include/modbus'
make[1]: Leaving directory `/usr/src/libmodbus-3.0.6/src'
Making install in doc
make[1]: Entering directory `/usr/src/libmodbus-3.0.6/doc'
make[2]: Nothing to be done for `install-exec-am'.
/bin/mkdir -p '/usr/local/share/man/man3'
/usr/bin/install -c -m 644 modbus_close.3 modbus_connect.3 modbus_flush.3 modbus_free.3 modbus_get_byte_from_bits.3 modbus_get_byte_timeout.3 modbus_get_float.3 modbus_get_header_length.3 modbus_get_response_timeout.3 modbus_get_socket.3 modbus_mapping_free.3 modbus_mapping_new.3 modbus_new_rtu.3 modbus_new_tcp_pi.3 modbus_new_tcp.3 modbus_read_bits.3 modbus_read_input_bits.3 modbus_read_input_registers.3 modbus_read_registers.3 modbus_receive_confirmation.3 modbus_receive_from.3 modbus_receive.3 modbus_reply_exception.3 modbus_reply.3 modbus_report_slave_id.3 modbus_rtu_get_serial_mode.3 modbus_rtu_set_serial_mode.3 modbus_send_raw_request.3 modbus_set_bits_from_bytes.3 modbus_set_bits_from_byte.3 modbus_set_byte_timeout.3 modbus_set_debug.3 modbus_set_error_recovery.3 modbus_set_float.3 modbus_set_response_timeout.3 modbus_set_slave.3 modbus_set_socket.3 modbus_strerror.3 modbus_tcp_listen.3 modbus_write_and_read_registers.3 '/usr/local/share/man/man3'
/usr/bin/install -c -m 644 modbus_write_bits.3 modbus_write_bit.3 modbus_write_registers.3 modbus_write_register.3 '/usr/local/share/man/man3'
/bin/mkdir -p '/usr/local/share/man/man7'
/usr/bin/install -c -m 644 libmodbus.7 '/usr/local/share/man/man7'
make[1]: Leaving directory `/usr/src/libmodbus-3.0.6/doc'
Making install in tests
make[1]: Entering directory `/usr/src/libmodbus-3.0.6/tests'
make[2]: Nothing to be done for `install-data-am'.
make[1]: Leaving directory `/usr/src/libmodbus-3.0.6/tests'
/bin/mkdir -p '/usr/local/lib/pkgconfig'
/usr/bin/install -c -m 644 libmodbus.pc '/usr/local/lib/pkgconfig'
make[1]: Leaving directory `/usr/src/libmodbus-3.0.6'Code: Select all
In general, plugin can be build as usual
./autogen.sh
./configure
make
make installCode: Select all
[root@nagiosserver check_modbus-master]# ./autogen.sh
configure.ac:4: error: Autoconf version 2.67 or higher is required
configure.ac:4: the top level
autom4te: /usr/bin/m4 failed with exit status: 63
aclocal: autom4te failed with exit status: 63Code: Select all
[root@nagiosserver src]# wget http://ftp.gnu.org/gnu/autoconf/http://ftp.gnu.org/gnu/autoconf/autoconf-latest.tar.gz
--2014-08-04 13:30:27-- http://ftp.gnu.org/gnu/autoconf/autoconf-latest.tar.gz
Resolving ftp.gnu.org... 208.118.235.20, 2001:4830:134:3::b
Connecting to ftp.gnu.org|208.118.235.20|:80... connected.
Length: 1927468 (1.8M) [application/x-gzip]
Saving to: autoconf-latest.tar.gz
0% [ ] 0 --.-K/s
1% [> ] 23,819 115K/s
3% [===> ] 62,923 150K/s
5% [=======> ] 110,439 171K/s
12% [==================> ] 242,499 276K/s
25% [======================================> ] 499,519 448K/s
46% [=====================================================================> ] 888,599 673K/s
79% [========================================================================================================================> ] 1,536,119 1007K/s
100%[========================================================================================================================================================>] 1,927,468 1.10M/s in 1.7s
2014-08-04 13:30:29 (1.10 MB/s) - autoconf-latest.tar.gz saved [1927468/1927468]
[root@nagiosserver src]# tar -xzf autoconf-latest.tar.gz
[root@nagiosserver src]# cd autoconf-
autoconf-2.69/ autoconf-latest.tar.gz
[root@nagiosserver src]# cd autoconf-2.69/
[root@nagiosserver autoconf-2.69]# ls -l
total 1896
-rw-rw-r-- 1 root root 25205 Apr 25 2012 aclocal.m4
-rw-rw-r-- 1 root root 8052 Jan 21 2012 AUTHORS
drwxrwxr-x 2 root root 4096 Apr 25 2012 bin
-rw-rw-r-- 1 root root 1645 Jan 21 2012 BUGS
drwxrwxr-x 2 root root 4096 Apr 25 2012 build-aux
-rw-rw-r-- 1 root root 5407 Apr 25 2012 cfg.mk
-rw-rw-r-- 1 root root 21566 Apr 25 2012 ChangeLog
-rw-rw-r-- 1 root root 12943 Mar 5 2010 ChangeLog.0
-rw-rw-r-- 1 root root 68786 Mar 5 2010 ChangeLog.1
-rw-rw-r-- 1 root root 430071 Jan 21 2012 ChangeLog.2
-rw-rw-r-- 1 root root 855071 Apr 25 2012 ChangeLog.3
-rwxrwxr-x 1 root root 131992 Apr 25 2012 configure
-rw-rw-r-- 1 root root 7373 Apr 25 2012 configure.ac
-rw-rw-r-- 1 root root 17987 Mar 5 2010 COPYING
-rw-rw-r-- 1 root root 1865 Mar 5 2011 COPYING.EXCEPTION
-rw-rw-r-- 1 root root 35147 Mar 5 2010 COPYINGv3
drwxrwxr-x 2 root root 4096 Apr 25 2012 doc
-rw-rw-r-- 1 root root 4573 Apr 25 2012 GNUmakefile
-rw-rw-r-- 1 root root 15749 Mar 2 2012 INSTALL
drwxrwxr-x 8 root root 4096 Apr 25 2012 lib
drwxrwxr-x 2 root root 4096 Apr 25 2012 m4
-rw-rw-r-- 1 root root 58430 Apr 25 2012 maint.mk
-rw-rw-r-- 1 root root 5161 Feb 16 2012 Makefile.am
-rw-rw-r-- 1 root root 29348 Apr 25 2012 Makefile.in
drwxrwxr-x 2 root root 4096 Apr 25 2012 man
-rw-rw-r-- 1 root root 81635 Apr 25 2012 NEWS
-rw-rw-r-- 1 root root 2763 Mar 7 2012 README
drwxrwxr-x 2 root root 4096 Apr 25 2012 tests
-rw-rw-r-- 1 root root 21515 Jan 21 2012 THANKS
-rw-rw-r-- 1 root root 23570 Jan 21 2012 TODO
[root@nagiosserver autoconf-2.69]# make./configure ;make;make install;
configure: autobuild project... GNU Autoconf
configure: autobuild revision... 2.69
configure: autobuild hostname... nagiosserver.gentgrp.gent.be
configure: autobuild timestamp... 20140804T114327Z
checking whether /bin/sh -n is known to work... yes
checking for characters that cannot appear in file names... none
checking whether directories can have trailing spaces... yes
checking for expr... /usr/bin/expr
checking for GNU M4 that supports accurate traces... /usr/bin/m4
checking whether /usr/bin/m4 accepts --gnu... yes
checking how m4 supports trace files... --debugfile
checking for perl... /usr/bin/perl
checking whether /usr/bin/perl Fcntl::flock is implemented... yes
checking for emacs... no
checking for xemacs... no
checking where .elc files should go... ${datadir}/emacs/site-lisp
checking whether make is case sensitive... yes
config.status: creating tests/atlocal
config.status: creating man/Makefile
config.status: creating lib/emacs/Makefile
config.status: creating lib/Makefile
config.status: creating lib/Autom4te/Makefile
config.status: creating lib/autoscan/Makefile
config.status: creating lib/m4sugar/Makefile
config.status: creating lib/autoconf/Makefile
config.status: creating lib/autotest/Makefile
config.status: creating bin/Makefile
config.status: executing tests/atconfig commands
make all-recursive
make[1]: Entering directory `/usr/src/autoconf-2.69'
Making all in bin
make[2]: Entering directory `/usr/src/autoconf-2.69/bin'
rm -f autom4te autom4te.tmp
srcdir=''; \
test -f ./autom4te.in || srcdir=./; \
sed -e 's|@SHELL[@]|/bin/sh|g' -e 's|@PERL[@]|/usr/bin/perl|g' -e 's|@PERL_FLOCK[@]|yes|g' -e 's|@bindir[@]|/usr/local/bin|g' -e 's|@pkgdatadir[@]|/usr/local/share/autoconf|g' -e 's|@prefix[@]|/usr/local|g' -e 's|@autoconf-name[@]|'`echo autoconf | sed 's,x,x,'`'|g' -e 's|@autoheader-name[@]|'`echo autoheader | sed 's,x,x,'`'|g' -e 's|@autom4te-name[@]|'`echo autom4te | sed 's,x,x,'`'|g' -e 's|@M4[@]|/usr/bin/m4|g' -e 's|@M4_DEBUGFILE[@]|--debugfile|g' -e 's|@M4_GNU[@]|--gnu|g' -e 's|@AWK[@]|gawk|g' -e 's|@RELEASE_YEAR[@]|'`sed 's/^\([0-9][0-9][0-9][0-9]\).*/\1/;q' ../ChangeLog`'|g' -e 's|@VERSION[@]|2.69|g' -e 's|@PACKAGE_NAME[@]|GNU Autoconf|g' -e 's|@configure_input[@]|Generated from autom4te.in; do not edit by hand.|g' ${srcdir}autom4te.in >autom4te.tmp
chmod +x autom4te.tmp
chmod a-w autom4te.tmp
mv autom4te.tmp autom4te
cd ../lib && make autom4te.cfg
make[3]: Entering directory `/usr/src/autoconf-2.69/lib'
rm -f autom4te.cfg autom4te.tmp
sed -e 's|@SHELL[@]|/bin/sh|g' -e 's|@PERL[@]|/usr/bin/perl|g' -e 's|@bindir[@]|/usr/local/bin|g' -e 's|@pkgdatadir[@]|/usr/local/share/autoconf|g' -e 's|@prefix[@]|/usr/local|g' -e 's|@autoconf-name[@]|'`echo autoconf | sed 's,x,x,'`'|g' -e 's|@autoheader-name[@]|'`echo autoheader | sed 's,x,x,'`'|g' -e 's|@autom4te-name[@]|'`echo autom4te | sed 's,x,x,'`'|g' -e 's|@M4[@]|/usr/bin/m4|g' -e 's|@AWK[@]|gawk|g' -e 's|@VERSION[@]|2.69|g' -e 's|@PACKAGE_NAME[@]|GNU Autoconf|g' ./autom4te.in >autom4te.tmp
mv autom4te.tmp autom4te.cfg
make[3]: Leaving directory `/usr/src/autoconf-2.69/lib'
cd ../lib/m4sugar && make version.m4
make[3]: Entering directory `/usr/src/autoconf-2.69/lib/m4sugar'
echo '# This file is part of -*- Autoconf -*-.' && \
echo '# Version of Autoconf.' && \
echo '# Copyright (C) 1999, 2000, 2001, 2002, 2006, 2007, 2009' && \
echo '# Free Software Foundation, Inc.' && \
echo &&\
echo 'm4_define([m4_PACKAGE_NAME], [GNU Autoconf])' && \
echo 'm4_define([m4_PACKAGE_TARNAME], [autoconf])' && \
echo 'm4_define([m4_PACKAGE_VERSION], [2.69])' && \
echo 'm4_define([m4_PACKAGE_STRING], [GNU Autoconf 2.69])' && \
echo 'm4_define([m4_PACKAGE_BUGREPORT], [[email protected]])' && \
echo 'm4_define([m4_PACKAGE_URL], [http://www.gnu.org/software/autoconf/])' && \
echo 'm4_define([m4_PACKAGE_YEAR], ['`sed 's/^\([0-9][0-9][0-9][0-9]\).*/\1/;q' ../../ChangeLog`'])'; \
} > version.m4-t
mv version.m4-t version.m4
make[3]: Leaving directory `/usr/src/autoconf-2.69/lib/m4sugar'
autom4te_perllibdir='..'/lib AUTOM4TE_CFG='../lib/autom4te.cfg' ../bin/autom4te -B '..'/lib -B '..'/lib --language M4sh --cache '' --melt ./autoconf.as -o autoconf.in
rm -f autoconf autoconf.tmp
srcdir=''; \
test -f ./autoconf.in || srcdir=./; \
sed -e 's|@SHELL[@]|/bin/sh|g' -e 's|@PERL[@]|/usr/bin/perl|g' -e 's|@PERL_FLOCK[@]|yes|g' -e 's|@bindir[@]|/usr/local/bin|g' -e 's|@pkgdatadir[@]|/usr/local/share/autoconf|g' -e 's|@prefix[@]|/usr/local|g' -e 's|@autoconf-name[@]|'`echo autoconf | sed 's,x,x,'`'|g' -e 's|@autoheader-name[@]|'`echo autoheader | sed 's,x,x,'`'|g' -e 's|@autom4te-name[@]|'`echo autom4te | sed 's,x,x,'`'|g' -e 's|@M4[@]|/usr/bin/m4|g' -e 's|@M4_DEBUGFILE[@]|--debugfile|g' -e 's|@M4_GNU[@]|--gnu|g' -e 's|@AWK[@]|gawk|g' -e 's|@RELEASE_YEAR[@]|'`sed 's/^\([0-9][0-9][0-9][0-9]\).*/\1/;q' ../ChangeLog`'|g' -e 's|@VERSION[@]|2.69|g' -e 's|@PACKAGE_NAME[@]|GNU Autoconf|g' -e 's|@configure_input[@]|Generated from autoconf.in; do not edit by hand.|g' ${srcdir}autoconf.in >autoconf.tmp
chmod +x autoconf.tmp
chmod a-w autoconf.tmp
mv autoconf.tmp autoconf
rm -f autoheader autoheader.tmp
srcdir=''; \
test -f ./autoheader.in || srcdir=./; \
sed -e 's|@SHELL[@]|/bin/sh|g' -e 's|@PERL[@]|/usr/bin/perl|g' -e 's|@PERL_FLOCK[@]|yes|g' -e 's|@bindir[@]|/usr/local/bin|g' -e 's|@pkgdatadir[@]|/usr/local/share/autoconf|g' -e 's|@prefix[@]|/usr/local|g' -e 's|@autoconf-name[@]|'`echo autoconf | sed 's,x,x,'`'|g' -e 's|@autoheader-name[@]|'`echo autoheader | sed 's,x,x,'`'|g' -e 's|@autom4te-name[@]|'`echo autom4te | sed 's,x,x,'`'|g' -e 's|@M4[@]|/usr/bin/m4|g' -e 's|@M4_DEBUGFILE[@]|--debugfile|g' -e 's|@M4_GNU[@]|--gnu|g' -e 's|@AWK[@]|gawk|g' -e 's|@RELEASE_YEAR[@]|'`sed 's/^\([0-9][0-9][0-9][0-9]\).*/\1/;q' ../ChangeLog`'|g' -e 's|@VERSION[@]|2.69|g' -e 's|@PACKAGE_NAME[@]|GNU Autoconf|g' -e 's|@configure_input[@]|Generated from autoheader.in; do not edit by hand.|g' ${srcdir}autoheader.in >autoheader.tmp
chmod +x autoheader.tmp
chmod a-w autoheader.tmp
mv autoheader.tmp autoheader
rm -f autoreconf autoreconf.tmp
srcdir=''; \
test -f ./autoreconf.in || srcdir=./; \
sed -e 's|@SHELL[@]|/bin/sh|g' -e 's|@PERL[@]|/usr/bin/perl|g' -e 's|@PERL_FLOCK[@]|yes|g' -e 's|@bindir[@]|/usr/local/bin|g' -e 's|@pkgdatadir[@]|/usr/local/share/autoconf|g' -e 's|@prefix[@]|/usr/local|g' -e 's|@autoconf-name[@]|'`echo autoconf | sed 's,x,x,'`'|g' -e 's|@autoheader-name[@]|'`echo autoheader | sed 's,x,x,'`'|g' -e 's|@autom4te-name[@]|'`echo autom4te | sed 's,x,x,'`'|g' -e 's|@M4[@]|/usr/bin/m4|g' -e 's|@M4_DEBUGFILE[@]|--debugfile|g' -e 's|@M4_GNU[@]|--gnu|g' -e 's|@AWK[@]|gawk|g' -e 's|@RELEASE_YEAR[@]|'`sed 's/^\([0-9][0-9][0-9][0-9]\).*/\1/;q' ../ChangeLog`'|g' -e 's|@VERSION[@]|2.69|g' -e 's|@PACKAGE_NAME[@]|GNU Autoconf|g' -e 's|@configure_input[@]|Generated from autoreconf.in; do not edit by hand.|g' ${srcdir}autoreconf.in >autoreconf.tmp
chmod +x autoreconf.tmp
chmod a-w autoreconf.tmp
mv autoreconf.tmp autoreconf
rm -f ifnames ifnames.tmp
srcdir=''; \
test -f ./ifnames.in || srcdir=./; \
sed -e 's|@SHELL[@]|/bin/sh|g' -e 's|@PERL[@]|/usr/bin/perl|g' -e 's|@PERL_FLOCK[@]|yes|g' -e 's|@bindir[@]|/usr/local/bin|g' -e 's|@pkgdatadir[@]|/usr/local/share/autoconf|g' -e 's|@prefix[@]|/usr/local|g' -e 's|@autoconf-name[@]|'`echo autoconf | sed 's,x,x,'`'|g' -e 's|@autoheader-name[@]|'`echo autoheader | sed 's,x,x,'`'|g' -e 's|@autom4te-name[@]|'`echo autom4te | sed 's,x,x,'`'|g' -e 's|@M4[@]|/usr/bin/m4|g' -e 's|@M4_DEBUGFILE[@]|--debugfile|g' -e 's|@M4_GNU[@]|--gnu|g' -e 's|@AWK[@]|gawk|g' -e 's|@RELEASE_YEAR[@]|'`sed 's/^\([0-9][0-9][0-9][0-9]\).*/\1/;q' ../ChangeLog`'|g' -e 's|@VERSION[@]|2.69|g' -e 's|@PACKAGE_NAME[@]|GNU Autoconf|g' -e 's|@configure_input[@]|Generated from ifnames.in; do not edit by hand.|g' ${srcdir}ifnames.in >ifnames.tmp
chmod +x ifnames.tmp
chmod a-w ifnames.tmp
mv ifnames.tmp ifnames
rm -f autoscan autoscan.tmp
srcdir=''; \
test -f ./autoscan.in || srcdir=./; \
sed -e 's|@SHELL[@]|/bin/sh|g' -e 's|@PERL[@]|/usr/bin/perl|g' -e 's|@PERL_FLOCK[@]|yes|g' -e 's|@bindir[@]|/usr/local/bin|g' -e 's|@pkgdatadir[@]|/usr/local/share/autoconf|g' -e 's|@prefix[@]|/usr/local|g' -e 's|@autoconf-name[@]|'`echo autoconf | sed 's,x,x,'`'|g' -e 's|@autoheader-name[@]|'`echo autoheader | sed 's,x,x,'`'|g' -e 's|@autom4te-name[@]|'`echo autom4te | sed 's,x,x,'`'|g' -e 's|@M4[@]|/usr/bin/m4|g' -e 's|@M4_DEBUGFILE[@]|--debugfile|g' -e 's|@M4_GNU[@]|--gnu|g' -e 's|@AWK[@]|gawk|g' -e 's|@RELEASE_YEAR[@]|'`sed 's/^\([0-9][0-9][0-9][0-9]\).*/\1/;q' ../ChangeLog`'|g' -e 's|@VERSION[@]|2.69|g' -e 's|@PACKAGE_NAME[@]|GNU Autoconf|g' -e 's|@configure_input[@]|Generated from autoscan.in; do not edit by hand.|g' ${srcdir}autoscan.in >autoscan.tmp
chmod +x autoscan.tmp
chmod a-w autoscan.tmp
mv autoscan.tmp autoscan
rm -f autoupdate autoupdate.tmp
srcdir=''; \
test -f ./autoupdate.in || srcdir=./; \
sed -e 's|@SHELL[@]|/bin/sh|g' -e 's|@PERL[@]|/usr/bin/perl|g' -e 's|@PERL_FLOCK[@]|yes|g' -e 's|@bindir[@]|/usr/local/bin|g' -e 's|@pkgdatadir[@]|/usr/local/share/autoconf|g' -e 's|@prefix[@]|/usr/local|g' -e 's|@autoconf-name[@]|'`echo autoconf | sed 's,x,x,'`'|g' -e 's|@autoheader-name[@]|'`echo autoheader | sed 's,x,x,'`'|g' -e 's|@autom4te-name[@]|'`echo autom4te | sed 's,x,x,'`'|g' -e 's|@M4[@]|/usr/bin/m4|g' -e 's|@M4_DEBUGFILE[@]|--debugfile|g' -e 's|@M4_GNU[@]|--gnu|g' -e 's|@AWK[@]|gawk|g' -e 's|@RELEASE_YEAR[@]|'`sed 's/^\([0-9][0-9][0-9][0-9]\).*/\1/;q' ../ChangeLog`'|g' -e 's|@VERSION[@]|2.69|g' -e 's|@PACKAGE_NAME[@]|GNU Autoconf|g' -e 's|@configure_input[@]|Generated from autoupdate.in; do not edit by hand.|g' ${srcdir}autoupdate.in >autoupdate.tmp
chmod +x autoupdate.tmp
chmod a-w autoupdate.tmp
mv autoupdate.tmp autoupdate
make[2]: Leaving directory `/usr/src/autoconf-2.69/bin'
Making all in .
make[2]: Entering directory `/usr/src/autoconf-2.69'
make[2]: Nothing to be done for `all-am'.
make[2]: Leaving directory `/usr/src/autoconf-2.69'
Making all in lib
make[2]: Entering directory `/usr/src/autoconf-2.69/lib'
Making all in Autom4te
make[3]: Entering directory `/usr/src/autoconf-2.69/lib/Autom4te'
make[3]: Nothing to be done for `all'.
make[3]: Leaving directory `/usr/src/autoconf-2.69/lib/Autom4te'
Making all in m4sugar
autom4te_perllibdir='../..'/lib AUTOM4TE_CFG='../../lib/autom4te.cfg' ../../bin/autom4te -B '../..'/lib -B '../..'/lib \
--language=m4sugar\
--freeze\
--output=m4sugar.m4f
--language=m4sh\
--freeze\
--output=m4sh.m4f
Making all in autoconf
make[3]: Entering directory `/usr/src/autoconf-2.69/lib/autoconf'
--language=autoconf\
--freeze\
--output=autoconf.m4f
make[3]: Leaving directory `/usr/src/autoconf-2.69/lib/autoconf'
Making all in autotest
make[3]: Entering directory `/usr/src/autoconf-2.69/lib/autotest'
--language=autotest\
--freeze\
--output=autotest.m4f
make[3]: Leaving directory `/usr/src/autoconf-2.69/lib/autotest'
Making all in autoscan
make[3]: Entering directory `/usr/src/autoconf-2.69/lib/autoscan'
echo '# Automatically Generated: do not edit this file' >autoscan.list
sed '/^[#]/!q' ./autoscan.pre >>autoscan.list
sed -n '/^[^#]/p' ./autoscan.pre; \
autom4te_perllibdir='../..'/lib AUTOM4TE_CFG='../../lib/autom4te.cfg' ../../bin/autom4te -B '../..'/lib -B '../..'/lib --cache '' -M -l autoconf -t'AN_OUTPUT:$1: $2$3' \
) | LC_ALL=C sort >>autoscan.list
make[3]: Leaving directory `/usr/src/autoconf-2.69/lib/autoscan'
Making all in emacs
make[3]: Entering directory `/usr/src/autoconf-2.69/lib/emacs'
WARNING: Warnings can be ignored. :-)
if test "no" != no; then \
set x; \
list='autoconf-mode.el autotest-mode.el'; for p in $list; do \
if test -f "$p"; then d=; else d="./"; fi; \
set x "$@" "$d$p"; shift; \
done; \
shift; \
EMACS="no" /bin/sh ../../build-aux/elisp-comp "$@" || exit 1; \
else : ; fi
make[3]: Leaving directory `/usr/src/autoconf-2.69/lib/emacs'
make[3]: Nothing to be done for `all-am'.
make[2]: Leaving directory `/usr/src/autoconf-2.69/lib'
Making all in doc
make[2]: Entering directory `/usr/src/autoconf-2.69/doc'
make[2]: Leaving directory `/usr/src/autoconf-2.69/doc'
Making all in tests
make[2]: Entering directory `/usr/src/autoconf-2.69/tests'
autom4te_perllibdir='..'/lib AUTOM4TE_CFG='../lib/autom4te.cfg' ../bin/autom4te -B '..'/lib -B '..'/lib --language=M4sh ./wrapper.as -o wrapper.in
input=wrapper.in; \
sed -e 's|@wrap_program[@]|autoconf|g' -e 's|@abs_top_srcdir[@]|/usr/src/autoconf-2.69|g' -e 's|@abs_top_builddir[@]|/usr/src/autoconf-2.69|g' -e "s|@configure_input[@]|Generated from $input.|g" wrapper.in >autoconf.tmp
mv -f autoconf.tmp autoconf
input=wrapper.in; \
sed -e 's|@wrap_program[@]|autoheader|g' -e 's|@abs_top_srcdir[@]|/usr/src/autoconf-2.69|g' -e 's|@abs_top_builddir[@]|/usr/src/autoconf-2.69|g' -e "s|@configure_input[@]|Generated from $input.|g" wrapper.in >autoheader.tmp
mv -f autoheader.tmp autoheader
input=wrapper.in; \
sed -e 's|@wrap_program[@]|autom4te|g' -e 's|@abs_top_srcdir[@]|/usr/src/autoconf-2.69|g' -e 's|@abs_top_builddir[@]|/usr/src/autoconf-2.69|g' -e "s|@configure_input[@]|Generated from $input.|g" wrapper.in >autom4te.tmp
mv -f autom4te.tmp autom4te
input=wrapper.in; \
sed -e 's|@wrap_program[@]|autoreconf|g' -e 's|@abs_top_srcdir[@]|/usr/src/autoconf-2.69|g' -e 's|@abs_top_builddir[@]|/usr/src/autoconf-2.69|g' -e "s|@configure_input[@]|Generated from $input.|g" wrapper.in >autoreconf.tmp
mv -f autoreconf.tmp autoreconf
input=wrapper.in; \
sed -e 's|@wrap_program[@]|autoscan|g' -e 's|@abs_top_srcdir[@]|/usr/src/autoconf-2.69|g' -e 's|@abs_top_builddir[@]|/usr/src/autoconf-2.69|g' -e "s|@configure_input[@]|Generated from $input.|g" wrapper.in >autoscan.tmp
mv -f autoscan.tmp autoscan
input=wrapper.in; \
sed -e 's|@wrap_program[@]|autoupdate|g' -e 's|@abs_top_srcdir[@]|/usr/src/autoconf-2.69|g' -e 's|@abs_top_builddir[@]|/usr/src/autoconf-2.69|g' -e "s|@configure_input[@]|Generated from $input.|g" wrapper.in >autoupdate.tmp
mv -f autoupdate.tmp autoupdate
input=wrapper.in; \
sed -e 's|@wrap_program[@]|ifnames|g' -e 's|@abs_top_srcdir[@]|/usr/src/autoconf-2.69|g' -e 's|@abs_top_builddir[@]|/usr/src/autoconf-2.69|g' -e "s|@configure_input[@]|Generated from $input.|g" wrapper.in >ifnames.tmp
mv -f ifnames.tmp ifnames
make[2]: Leaving directory `/usr/src/autoconf-2.69/tests'
Making all in man
make[2]: Entering directory `/usr/src/autoconf-2.69/man'
make[2]: Leaving directory `/usr/src/autoconf-2.69/man'
make[1]: Leaving directory `/usr/src/autoconf-2.69'
make install-recursive
Making install in bin
make[3]: Entering directory `/usr/src/autoconf-2.69/bin'
test -z "/usr/local/bin" || /bin/mkdir -p "/usr/local/bin"
/usr/bin/install -c autom4te autoconf autoheader autoreconf ifnames autoscan autoupdate '/usr/local/bin'
make[3]: Nothing to be done for `install-data-am'.
make[3]: Leaving directory `/usr/src/autoconf-2.69/bin'
Making install in .
make[3]: Entering directory `/usr/src/autoconf-2.69'
make[3]: Nothing to be done for `install-exec-am'.
test -z "/usr/local/share/autoconf" || /bin/mkdir -p "/usr/local/share/autoconf"
/usr/bin/install -c -m 644 ./INSTALL '/usr/local/share/autoconf'
make[3]: Leaving directory `/usr/src/autoconf-2.69'
Making install in lib
Making install in Autom4te
make[4]: Entering directory `/usr/src/autoconf-2.69/lib/Autom4te'
make[4]: Nothing to be done for `install-exec-am'.
test -z "/usr/local/share/autoconf/Autom4te" || /bin/mkdir -p "/usr/local/share/autoconf/Autom4te"
/usr/bin/install -c -m 644 C4che.pm ChannelDefs.pm Channels.pm Configure_ac.pm FileUtils.pm General.pm Getopt.pm Request.pm XFile.pm '/usr/local/share/autoconf/Autom4te'
make[4]: Leaving directory `/usr/src/autoconf-2.69/lib/Autom4te'
Making install in m4sugar
make[4]: Entering directory `/usr/src/autoconf-2.69/lib/m4sugar'
test -z "/usr/local/share/autoconf/m4sugar" || /bin/mkdir -p "/usr/local/share/autoconf/m4sugar"
/usr/bin/install -c -m 644 m4sugar.m4 foreach.m4 m4sh.m4 '/usr/local/share/autoconf/m4sugar'
/usr/bin/install -c -m 644 version.m4 m4sugar.m4f m4sh.m4f '/usr/local/share/autoconf/m4sugar'
make[4]: Leaving directory `/usr/src/autoconf-2.69/lib/m4sugar'
Making install in autoconf
make[4]: Entering directory `/usr/src/autoconf-2.69/lib/autoconf'
test -z "/usr/local/share/autoconf/autoconf" || /bin/mkdir -p "/usr/local/share/autoconf/autoconf"
/usr/bin/install -c -m 644 autoconf.m4 general.m4 status.m4 oldnames.m4 specific.m4 autoheader.m4 autoupdate.m4 autotest.m4 autoscan.m4 lang.m4 c.m4 erlang.m4 fortran.m4 functions.m4 go.m4 headers.m4 types.m4 libs.m4 programs.m4 '/usr/local/share/autoconf/autoconf'
/usr/bin/install -c -m 644 autoconf.m4f '/usr/local/share/autoconf/autoconf'
make[4]: Leaving directory `/usr/src/autoconf-2.69/lib/autoconf'
Making install in autotest
make[4]: Entering directory `/usr/src/autoconf-2.69/lib/autotest'
test -z "/usr/local/share/autoconf/autotest" || /bin/mkdir -p "/usr/local/share/autoconf/autotest"
/usr/bin/install -c -m 644 autotest.m4 general.m4 specific.m4 '/usr/local/share/autoconf/autotest'
/usr/bin/install -c -m 644 autotest.m4f '/usr/local/share/autoconf/autotest'
make[4]: Leaving directory `/usr/src/autoconf-2.69/lib/autotest'
Making install in autoscan
make[4]: Entering directory `/usr/src/autoconf-2.69/lib/autoscan'
test -z "/usr/local/share/autoconf/autoscan" || /bin/mkdir -p "/usr/local/share/autoconf/autoscan"
/usr/bin/install -c -m 644 autoscan.list '/usr/local/share/autoconf/autoscan'
make[4]: Leaving directory `/usr/src/autoconf-2.69/lib/autoscan'
Making install in emacs
make[4]: Entering directory `/usr/src/autoconf-2.69/lib/emacs'
make[4]: Leaving directory `/usr/src/autoconf-2.69/lib/emacs'
make[4]: Entering directory `/usr/src/autoconf-2.69/lib'
/usr/bin/install -c -m 644 autom4te.cfg '/usr/local/share/autoconf'
make[4]: Leaving directory `/usr/src/autoconf-2.69/lib'
make[3]: Entering directory `/usr/src/autoconf-2.69/doc'
test -z "/usr/local/share/info" || /bin/mkdir -p "/usr/local/share/info"
/usr/bin/install -c -m 644 ./autoconf.info ./standards.info '/usr/local/share/info'
install-info --info-dir='/usr/local/share/info' '/usr/local/share/info/autoconf.info'
install-info --info-dir='/usr/local/share/info' '/usr/local/share/info/standards.info'
make[3]: Leaving directory `/usr/src/autoconf-2.69/doc'
make[3]: Entering directory `/usr/src/autoconf-2.69/tests'
make[3]: Leaving directory `/usr/src/autoconf-2.69/tests'
Making install in man
make[3]: Entering directory `/usr/src/autoconf-2.69/man'
test -z "/usr/local/share/man/man1" || /bin/mkdir -p "/usr/local/share/man/man1"
/usr/bin/install -c -m 644 ./autoconf.1 ./autoheader.1 ./autom4te.1 ./autoreconf.1 ./autoscan.1 ./autoupdate.1 ./ifnames.1 ./config.guess.1 ./config.sub.1 '/usr/local/share/man/man1'
make[3]: Leaving directory `/usr/src/autoconf-2.69/man'
[root@nagiosserver autoconf-2.69]# cd ..
[root@nagiosserver src]# ls -l
total 2456
drwxrwxr-x 9 root root 4096 Aug 4 13:43 autoconf-2.69
-rw-r--r-- 1 root root 1927468 Apr 25 2012 autoconf-latest.tar.gz
drwxr-xr-x 7 root root 4096 Aug 4 13:24 check_modbus-master
drwxr-xr-x. 2 root root 4096 Sep 23 2011 debug
drwxr-xr-x. 2 root root 4096 Sep 23 2011 kernels
drwxr-xr-x 6 1000 users 4096 Aug 4 13:04 libmodbus-3.0.6
-rw-r--r-- 1 root root 504757 May 16 23:50 libmodbus-3.0.6.tar.gz
-rw-r--r-- 1 root root 55569 Aug 4 13:01 master
[root@nagiosserver src]# cd check_modbus-master/
configure.ac:51: warning: AC_LANG_CONFTEST: no AC_LANG_SOURCE call detected in body
../../lib/autoconf/lang.m4:193: AC_LANG_CONFTEST is expanded from...
../../lib/autoconf/general.m4:2590: _AC_COMPILE_IFELSE is expanded from...
../../lib/autoconf/general.m4:2606: AC_COMPILE_IFELSE is expanded from...
../../lib/m4sugar/m4sh.m4:639: AS_IF is expanded from...
../../lib/autoconf/general.m4:2031: AC_CACHE_VAL is expanded from...
m4/attributes.m4:38: CC_CHECK_CFLAGS_SILENT is expanded from...
m4/attributes.m4:67: CC_CHECK_CFLAG_APPEND is expanded from...
m4/attributes.m4:78: CC_CHECK_CFLAGS_APPEND is expanded from...
configure.ac:51: the top level
configure.ac:18: installing `./config.guess'
configure.ac:18: installing `./config.sub'
configure.ac:7: installing `./install-sh'
configure.ac:7: installing `./missing'
src/Makefile.am: installing `./depcomp'
Ready to run ./configure
[root@nagiosserver check_modbus-master]# ./configure
checking for library containing modbus_set_slave... -lmodbus
checking for ANSI C header files... no
checking for stdint.h... (cached) yes
checking for stdlib.h... (cached) yes
checking modbus.h usability... no
checking modbus.h presence... no
checking for modbus.h... no
checking for int16_t... yes
checking for int32_t... yes
checking for int8_t... yes
checking for uint16_t... yes
checking for uint32_t... yes
checking for uint8_t... yes
checking for modbus_new_tcp_pi... yes
checking if gcc supports -Wall flag... yes
checking if gcc supports -Wextra flag... yes
checking if gcc supports -Wpedantic flag... no
checking if gcc supports -Wc++-compat flag... yes
checking if gcc supports -Wmissing-declarations flag... yes
checking if gcc supports -Wmissing-prototypes flag... yes
checking if gcc supports -Wformat-security flag... yes
config.status: creating m4/Makefile
config.status: executing depfiles commandsCode: Select all
[root@nagiosserver check_modbus-master]# make
Making all in src
make[1]: Entering directory `/usr/src/check_modbus-master/src'
gcc -DPACKAGE_NAME=\"check_modbus\" -DPACKAGE_TARNAME=\"check_modbus\" -DPACKAGE_VERSION=\"0.47\" -DPACKAGE_STRING=\"check_modbus\ 0.47\" -DPACKAGE_BUGREPORT=\"Andrej.Skvortzov-at-gmail.com\" -DPACKAGE_URL=\"\" -DPACKAGE=\"check_modbus\" -DVERSION=\"0.47\" -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_STDINT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_UNISTD_H=1 -DHAVE_MODBUS_NEW_TCP_PI=1 -I. -g -O2 -Wall -Wextra -Wc++-compat -Wmissing-declarations -Wmissing-prototypes -Wformat-security -MT command_line.o -MD -MP -MF .deps/command_line.Tpo -c -o command_line.o command_line.c
In file included from command_line.h:31,
from command_line.c:35:
check_modbus.h:31:20: error: ranges.h: No such file or directory
check_modbus.h:59: error: field warn_range has incomplete type
check_modbus.h:60: error: field crit_range has incomplete type
command_line.c: In function print_settings:
command_line.c:159: warning: implicit declaration of function fprint_range
command_line.c: In function parse_command_line:
command_line.c:554: warning: implicit declaration of function parse_range
make[1]: *** [command_line.o] Error 1
make[1]: Leaving directory `/usr/src/check_modbus-master/src'
make: *** [all-recursive] Error 1
[root@nagiosserver check_modbus-master]# make install
make: *** [install-recursive] Error 1
[root@nagiosserver check_modbus-master]# locate check_modbus
[root@nagiosserver check_modbus-master]# check_modbus
-bash: check_modbus: command not found
[root@nagiosserver check_modbus-master]# man check_modbus
No manual entry for check_modbusCode: Select all
1. Via root shell, navigate to some comfortable place like /usr/src/.
[root@ /]# cd /usr/src/
2. Download and extract libmodbus library and useful check_modbus app that will query info to Nagios for us:
[root@ src]# wget https://github.com/AndreySV/check_modbus/archive/master.zip mirror
[root@ src]# wget http://libmodbus.org/download/libmodbus-3.0.6.tar.gz mirror
3. Untar libmodbus archive, enter libmodbus directory and install it:
[root@ libmodbus-3.0.6]# ./configure;make;make install;
4. In same fashion install check_modbus:
[root@ check_modbus-master]# ./configure LDFLAGS=-L/usr/local/lib CPPFLAGS=-I/usr/local/include;
[root@ check_modbus-master]# make;make install;Code: Select all
[root@nagiosserver check_modbus-master]# ./configure LDFLAGS=-L/usr/local/lib CPPFLAGS=-I/usr/local/include;
[root@nagiosserver check_modbus-master]# make;make install;
Making all in src
gcc -DPACKAGE_NAME=\"check_modbus\" -DPACKAGE_TARNAME=\"check_modbus\" -DPACKAGE_VERSION=\"0.47\" -DPACKAGE_STRING=\"check_modbus\ 0.47\" -DPACKAGE_BUGREPORT=\"Andrej.Skvortzov-at-gmail.com\" -DPACKAGE_URL=\"\" -DPACKAGE=\"check_modbus\" -DVERSION=\"0.47\" -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_STDINT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_UNISTD_H=1 -DHAVE_MODBUS_NEW_TCP_PI=1 -I. -I/usr/local/include -g -O2 -Wall -Wextra -Wc++-compat -Wmissing-declarations -Wmissing-prototypes -Wformat-security -MT command_line.o -MD -MP -MF .deps/command_line.Tpo -c -o command_line.o command_line.c
make: *** [install-recursive] Error 1Willem
