Dashboard editing
SteveBeauchemin
Dashboard editing
Post by SteveBeauchemin »
For dashboards, once created, where is the configuration data?
I would much rather edit with vi than dragging with a mouse.
The screen sizes, locations, text, and any other items could be standardized if I could create a template that is then cloned and modified as needed.
Thanks.
Steve B
XI 5.7.3 / Core 4.4.6 / NagVis 1.9.8 / LiveStatus 1.5.0p11 / RRDCached 1.7.0 / Redis 3.2.8 /
SNMPTT / Gearman 0.33-7 / Mod_Gearman 3.0.7 / NLS 2.0.8 / NNA 2.3.1 /
NSClient 0.5.0 / NRPE Solaris 3.2.1 Linux 3.2.1 HPUX 3.2.1
jomann
Development Lead
Re: Dashboard editing
Post by jomann »
Dashboards are actually saved in the database. It's stored in the xi_usermeta tables in postgresql. It's actually a serialized array and wouldn't really be worth editing by hand but you can see what it looks like if you check your database.
SteveBeauchemin
Sounds nasty. Any chance of a simple GUI to change the Custom URL Dashlet data? Width, height, X and Y coords? Maybe fix a URL typo or something?
Delete and add is so old school. You can do better.
Steve B
WillemDH
Post by WillemDH »
Made a feature request for something like this 27/09/2013:
Maybe you could +1 it? :)
http://tracker.nagios.com/view.php?id=445
Grtz
Willem
Nagios XI 5.8.1
https://outsideit.net
I would recommend that SteveBeauchemin puts posts a comment on the tracker as well. This will "up" the changes for this being implemented.
