check_mysql_health : Return code of 25 is out of bounds
vAJ
Post by vAJ »
Have a check of a MySQL database that is constantly throwing the error: (Return code of 25 is out of bounds)
Command:
/usr/local/nagios/libexec/check_mysql_health --hostname=aus02nqhpmysq01.dev.*******.com --port=3306 --username=NagiosMon --password="**********" --database=information_schema --mode threadcache-hitrate --warning 90: --critical 80:
When I run this from he cl, I occasionally get this error:
Illegal division by zero at /usr/local/nagios/libexec/check_mysql_health line 488.
Thoughts? I'm running the latest version of this wizard. check_mysql_health (2.1)
Andrew J. - Do you even grok?
Re: check_mysql_health : Return code of 25 is out of bounds
Does it return correct sometimes?
By chance does aus02nqhpmysq01.dev.*******.com point to a loadbalancer IP or something of that nature, or is it a single server?
vAJ
Post by vAJ »
Single server and it responds well most of the time. One single poll will fail on occasion. Next poll corrects itself.
Looks like it's in the calculation of connections/sec, like python craps out on itself or something.
Could this server be reaching it max-connections (configurable in /etc/my.cnf)?
vAJ
Post by vAJ »
It's a lightly used dev/test mysql database with 5000 max connections. Doubt it's getting close to that. I found a python junkie on our development team that is going to dig into this script.
Did you mean to type a return of 255 or 25? If it is 25 I would suspect the script itself assigning the return value incorrectly (check the if/else clauses for the warn/crit values) but for 255 it could be anything really.
vAJ
Post by vAJ »
It's a 25.
The illegal division error when running from CLI makes me think it's a problem with the python itself. Looking at stats of the target in real time show it's doing absolutely nothing and I can only reproduce when execute the check in rapid fire.
abrist
Red Shirt
Post by abrist »
vAJ wrote:The illegal division error when running from CLI makes me think it's a problem with the python itself. Looking at stats of the target in real time show it's doing absolutely nothing and I can only reproduce when execute the check in rapid fire.
I would suspect that this is internal to the script itself. Just to clarify, the issue only happens when you run the same check multiple times near simultaneously?
vAJ
Post by vAJ »
Well, it happens occasionally as a scheduled check. My assumption is when the script returns the "Illeal Division" to Nagios, Nagios then displays that as "Return Code 25..."
abrist
Red Shirt
Post by abrist »
Are these checks running through multiple gearman servers? (One of the servers could have an issue)
It could also be that occasionally the check returns a bad value or unexpected character that is breaking the check or it could be occasionally timing out.
