Hi.
I'm trying to build a scripted nrds agent install package from a nas drive rather than using wget from an XI server.
I understand the implications with respect to the token and the XI server address and will accommodate that in the script.
I've looked for a similar question on the forums, but have had no luck.
Do you have a procedure you can point me to for this?
I can pore through the php scripts and deconstruct what the nrdsgetclient function is doing, but I'm hoping you can spare me the effort.
Thanks very much,
Rick
Install nrds agent from nas
Re: Install nrds agent from nas
In thinking more about this, I'm wondering if I could just tar up the /usr/local/nagios and /usr/local/nrdp directories from my installed agent and just put them on the nas. I could then make the appropriate nrds.cfg change, from my install script, to point to a passed XI server name and add the cron to run nrds.pl.
Seem reasonable?
It can't really be that simple, can it?
Seem reasonable?
You don't need all that. The easiest way would be to make a NRDS configuration from the UI, then click the disk icon in the UI to download the tarball you can place this on your NAS.grenley wrote:In thinking more about this, I'm wondering if I could just tar up the /usr/local/nagios and /usr/local/nrdp directories from my installed agent and just put them on the nas. I could then make the appropriate nrds.cfg change, from my install script, to point to a passed XI server name and add the cron to run nrds.pl.
Seem reasonable?
The only real changes you will need to make are in fact in the nrds.cfg
Once those changes are make run
./installnrds HOSTNAME INTERVALThe biggest thing is going to be making sure you have the correct token, XI server address and config name (needs to match a config on the server)
Much better approach.
Thanks very much Scott.
