Broken database
crafael01
Broken database
Post by crafael01 »
I came into work this morning to find this error message:
SQL: SQL Error [ndoutils] : Table './nagios/nagios_servicestatus' is marked as crashed and last (automatic?) repair failed SQL: SQL Error [ndoutils] : Table './nagios/nagios_servicestatus' is marked as crashed and last (automatic?) repair failed
Any idea how to recover from this?
Re: Broken database
Run the following:
/usr/local/nagiosxi/scripts/repair_databases.sh
crafael01
Re: Broken database
Post by crafael01 »
Thank you! It's working now, but I actually had to run ./repairmysql.sh nagios.
Re: Broken database
The command I posted runs that as part of the script:
#!/bin/sh
PATH=$PATH:/sbin:/usr/sbin
BASEDIR=$(dirname $0)
if [ ! -f "$BASEDIR/repair_databases.lock" ];then
    touch "$BASEDIR/repair_databases.lock"
    /sbin/service mysqld status
    mysqlstatus=$?
    if [ ! $mysqlstatus -eq 0 ];then
            rm -f /var/lib/mysql/mysql.sock
            /sbin/service mysqld start
    fi
    $BASEDIR/repairmysql.sh nagios
    $BASEDIR/repairmysql.sh nagiosql
    /sbin/service ndo2db restart
    /sbin/service nagios restart
    rm -f "$BASEDIR/repair_databases.lock"
fi
