Hi Team,
I am getting this error for Datastore Usage for VMHost monitor :
ESX3 CRITICAL - Can't use an undefined value as an ARRAY reference at /usr/local/nagios/libexec/check_esx3.pl line 1061.
All the remaining monitors like Memory for VMHost, CPU usage for VMHost etc. are working fine.
Please advice.
Regards,
Shinoj.
check_esx3 problem
Re: check_esx3 problem
Does the datastore exist? Does it have a size?
We have seen this issue before, and it is always related to a missing or size 0 datastore.
Datastores are configured and they have a non-zero size. PFA a screenshot.
Regards,
Shinoj.
Regards,
Shinoj.
What is the full command you are running?
Here is the command :
check_esx3_host!/usr/local/nagiosxi/etc/components/vmware/10_21_1_41_auth.txt!VMFS!
Regards,
Shinoj.
Regards,
Shinoj.
Can you verify the others (that are working) are using the came credentials file
I ask because I noticed that in your image the Host is 10.11.1.41, and it looks like this auth file was created for 10.21.1.41
The change in IP is because there is a NAT in between. Also, the credentials are correct - I get all the other details. Attached is a screenshot :
Regards,
Shinoj.
Regards,
Shinoj.
Can you post the full command as configured for the datastore check?
[root@localhost etc]# /usr/local/nagios/libexec/check_esx3.pl -H 10.21.1.41 -f /usr/local/nagiosxi/etc/components/vmware/10_21_1_41_auth.txt -l vmfs
Hope this is what you are looking for.
Regards,
Shinoj.
Regards,
Shinoj.
Are any of the volumes exceptionally large?
