NagiosXI Install Error
gunnerstahl
Post by gunnerstahl »
Linux Distribution and version? Centos 5.6
32 or 64bit? 64-bit
VMware Image or Manual Install of XI? Manual
Are there specials configurations on your system, ie; is Gnome installed? Are you using a proxy? Are you using SSL? Nope, No Gui
**If you are encountering multiple issues that may not be related, start a thread for each issue
ERROR: rpm-forge-release RPM was not installed - exiting.
RESULT=1
Re: NagiosXI Install Error
There has been an issue with the RPMForge changed URLs. Please, install RPMforge first, following the directons on this Web page:
http://wiki.centos.org/AdditionalResour ... s/RPMForge
Proceed with the Nagios Xi install as described in our documentation.
