CHECK_NRPE: Error - Could not complete SSL handshake
klee
Post by klee »
I set up NRPE according to this document.
http://nagios.sourceforge.net/docs/nrpe/NRPE.pdf
When I run the check with: /usr/local/nagios/libexec/check_nrpe -H localhost
CHECK_NRPE: Error - Could not complete SSL handshake.
I followed the troubleshooting tips for this specific error without success.
http://assets.nagios.com/downloads/nagi ... utions.pdf
Can you please advise?
-klee
Re: CHECK_NRPE: Error - Could not complete SSL handshake
What specifically did you follow in that document? Was NRPE compiled with SSL properly? Is the Nagios server IP allowed in the NRPE config?
klee
Post by klee »
I figure it out... I have to use 127.0.0.1 instead of localhost
/usr/local/nagios/libexec/check_nrpe -H 127.0.0.1
I'll leave this post up in case others search for the same error :)
Please close thread.
-klee
