Different ping graphs
WillemDH
Post by WillemDH »
Yesterday I cloned a host and today, looking at the graph explorer, I noticed there is a difference between the graphs of the clone source and the clone destination. The destination perfdata seems to contain rtmax and rtmin, while the source clone does not. They do use the same configuration.
I suspect this is a result of one of the latest updates. Is there a way to enable the rtmax and rtmin for older hosts too, so the graphs look the same?
Grtz
Willem
Nagios XI 5.8.1
https://outsideit.net
Re: Different ping graphs
This sounds pretty close to what you are experiencing, except that in your case the graphs are working properly and just need the new datasources:
http://support.nagios.com/wiki/index.ph ... 14_Upgrade
WillemDH
Post by WillemDH »
Thanks. I'll try this solution in the beginning of next week.
Nagios XI 5.8.1
Any updates?
WillemDH
Post by WillemDH »
Trevor,
I managed to find some time to execute the script in the wiki and the graphs seem to be consistent now.
Thanks for the guidance! Thread can be closed.
Grtz
Willem
Nagios XI 5.8.1
