Log entries table is huge!
BanditBBS
Post by BanditBBS »
I'm running out of disk space and I sort of found out why:
817.5M  nagios_logentries.MYI
1.5G    nagios_externalcommands.MYD
1.8G    nagios_logentries.TMD
3.6G    nagios_logentries.MYD
Look how large those 4 MySQL files are. Any way to make those smaller? I went to pefromance settings yesterday and set Max Log Entries from 90 to 60, but that made no change in the filesize. Should that have? Do I need to run the repair script?
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
Re: Log entries table is huge!
You will need to truncate these tables then run the repair on the database. Example:
mysql -u ndoutils -pn@gweb nagios -e 'TRUNCATE TABLE nagios_logentries'
Note: You will lose the historical data that was stored in these tables.
For more info, read the following document:
http://assets.nagios.com/downloads/nagi ... tabase.pdf
BanditBBS
Post by BanditBBS »
Lock her up!
