Tactical view differences
btemple
Post by btemple »
We have two separate xi server that are displaying different tactical views. My manager wants everything to be the same so I am not sure how to change the view.
They both point to the same ( tac.php ) since I backup and updated them to the same file but the difference is still there.
Both servers are Nagios XI 2014R1.3
We would like both servers to look like (example 1) if possible , bottom attachment
Re: Tactical view differences
It looks like the top one is using the XI tac and the bottom is using the Core tac. Click the gear on the right and post the full URLs for each.
Post by Box293 »
This is a feature that can be turned on or off:
