Error Trying to Repair Corrupt Table
[email protected]
Post by [email protected] »
When attempting an upgrade I received the following error...
Error: Got error 28 from storage engine when trying to dump tablespaces
Got error 144 Table ./nagios/nagios_notifications is marked as crashed.......
Tied to run myisamchk -r -f nagios_<corrupted_table> on the affected table but get a segmentation fault after the 2nd index repair runs.
Tried to run echo "use nagios;repair table nagios_notifications use_frm;" | mysql -pnagiosxi with no success.
Ideas?
Joe
abrist
Red Shirt
Re: Error Trying to Repair Corrupt Table
Post by abrist »
First, try our repair script:
/usr/local/nagiosxi/scripts/repairmysql.sh nagios
[email protected] wrote:Tied to run myisamchk -r -f nagios_<corrupted_table> on the affected table but get a segmentation fault after the 2nd index repair runs.
When a repair fails, it should not segfault. Try our script and report back.
[email protected]
Script runs and fails with segmentation fault. See attached screen grab.
Joe
abrist
Red Shirt
Post by abrist »
Well, the table may need to be truncated if all else fails. If you are a current customer, please send an email to [email protected] to open a ticket.
