Nagiosxi 2014R1.3
Service Perf Graphs time period not same as Report?
While pulling reports, after selecting "Last Month" as the period and checking "Display Performance Graphs" under the advanced options, the report comes in appropriately but the graphs for the performance metric is only for 24 hours? Should the graphs match the same time period also?
Thanks, Marcus
Nagiosxi 2014R1.3
Nagiosxi 2014R1.3
Re: Service Perf Graphs time period not same as Report?
Not seeing the same behavior on my system (see attached image). Does it happen for other hostgroups/servicegroups?
One would think so. In my tests it does work correctly as well. Can you post a screenshot showing the behavior of the graphs?
Ok, after reviewing your results, I did some testing on another one of my Nagios servers and found the following.
When I use the new graphs, it appears to work as your test indicates. When I use the old graphs, it only gives the last 24 hours ? I'm going to update to 2014R1.4 to see if things change. I'll follow up shortly.
Update: No change after upgrade to Nagios XI 2014r1.4.
Yeah, the old graphs (I believe), are statically set at 24 hours, this was before the ability to add perf graphs to your reports, that feature was added in 2014 when the switch over from the old PNP graphs, to the new hicharts ones occurred.
So is it possible to get the old graphs to work?
sreinhardt
- -fno-stack-protector
We can certainly put in a bug report and see, but I think this might be an issue with pnp templates more than anything. I'll put in an internal one after I verify the same issue, and see what comes of it.
