Cant show exim queue
pianunix
Post by pianunix »
Is there any clue about this error :
/usr/lib/nagios/plugins/check_nrpe -H server43012x -c check_exim
Mailqueue WARNING - query returned no output!
Pleas give us a clue about this ?
Thanks.
eloyd
Cool Title Here
Re: Cant show exim queue
Post by eloyd »
Yes. It is most likely the same error you reported in http://support.nagios.com/forum/viewtop ... 8&start=10.
pianunix
Post by pianunix »
I think centos wont recognize the nagios user
su -l -c "/usr/lib/nagios/plugins/check_eximqueue -w 30 -c 50"  nagios
This account is currently not available
but why the id of group was created ?
]# id nagios
uid=496(nagios) gid=497(nagios) groups=497(nagios)
 grep -ri 'nagios' /etc/passwd
nagios:x:496:497::/var/spool/nagios:/sbin/nologin
And when i executed as root the command was running just fine
# /usr/lib/nagios/plugins/check_eximqueue -w 30 -c 50
Mailqueue CRITICAL - 71 messages on queue
eloyd
Cool Title Here
Post by eloyd »
This is the exact same problem as your other one. You need to add the sudo command to your NRPE configuration (and possible your sudoers file).
pianunix
Post by pianunix »
Still wont work at all.
Another solution ?
pianunix
Post by pianunix »
Is there any clue that i can use check_mailq command on exim that using cPanel ?
eloyd
Cool Title Here
Post by eloyd »
Don't know anything about cPanel. Still thinking about options for you.
pianunix
Post by pianunix »
Right know i'm stil using this modul to show exim queue, but only work on host server :?
Mailqueue WARNING - 45 messages on queue
but when trying to show from host monitor, we get output error like this :
# /usr/lib/nagios/plugins/check_nrpe -H server43012x -c check_exim
NRPE: Unable to read output
This issue still wont solve, even i had fixed the permission nagios user, and also adding group exim to nagios but still cant work at all.
Is there any solution or clue about this ?
Thx
eloyd
Cool Title Here
Post by eloyd »
Nagios user on remote host needs a valid login shell, not disabled:
pianunix, haven't heard from you in a while. Did eloyd's advice help?
