NRDP send command
tariqondego
NRDP send command
Post by tariqondego »
I have NRDP server running at central.I have remote clients that need to send commands to the NRDP server and recieve results.Each client has send_nrdp.php installed.
How would i go about querying the server with commands? I mean what is the syntax for this?
And is there a way to schedule(autorun) this tasks,instead of having to type commands each time?
Please advise.
sreinhardt
-fno-stack-protector
Re: NRDP send command
Post by sreinhardt »
You can absolutely use something cron or scheduled tasks on windows to execute that. I would personally suggest using ncpa if you didn't want to manage it all manually and didn't mind an agent running on those systems. As for flags and usage, I will have to look in the morning when I am in the office. Otherwise you can always try to run it without anything and see what happens, or view the source, I seem to recall it being pretty straight forward.
tariqondego
Thanks,Cron will definately help.
below is how to use the client to send result:
/usr/bin/php  /usr/local/nrdp/clients/send_nrdp.php --url=<url> --token=<token> --host=<hostname> --service=<servicename> --state=<state> --output=<output>
a couple of questions:
1.How come when I run the above command nothing happens but only displays the send_nrdp.php source code?
2.Rather than having to type in the --state and --output,i want to be able to pick the actual values of these two, from nagios for a specified host,is this possible?
3.The above syntax submits check data,what is the syntax to submit a command?
Please advise and thanks in advance.
Post by slansing »
Can you show us an example of your send_nrdp.php command with the data filled out, and the output? I'd be interested in seeing what you are placing in there that might be causing that.
tariqondego
/usr/bin/php /usr/local/nrdp/clients/send_nrdp.php --url=http://192.168.1.5/nrdp --token=asd7fjk3l34
--host=comp1 --service=ping --state=0 --output="The service looks okay"
Same as from http://assets.nagios.com/downloads/nrdp ... erview.pdf manual
I have two instances of 4.0.7 running followed the same installation procedure on both,but strangely on inst1 its working ok and showing usage information,and when i use the full command to send to inst2,seems to be working ok.But nothing is being received on inst2.
When i run the same command on inst2 it shows the source code.
Please advise.
sreinhardt
So are you sending between two core systems, sending from two systems with nrdp installed to a core, or sending between two systems with just nrdp installed? Can you post the output that you are seeing from sending on both servers?
tariqondego
Yes I am sending between two core systems with nrdp server installed on both .
inst2.txt
(17.24 KiB) Downloaded 529 times
inst1.txt
(1.03 KiB) Downloaded 459 times
Can you run the following command on 192.168.1.5 box and show us the output?
grep asd7fjk3l34 /usr/local/nrdp/server/config.inc.php
Note: Modify the path to the "config.inc.php" if you need to.
tariqondego
Output:
"asd7fjk3l34",
Point is when I send the service check to 192.168.1.5,nothing gets received.
IS there a way to check for this?
send_nrdp client is on 192.168.1.5, so is it supposed to write this results someplace eg nagios.cmd?
How does it handover this information to nagios?
sreinhardt
The first place to look would be the apache access and error logs, on the system receiving the results. Something like:
grep -i '/nrdp' /var/log/httpd/error_log
grep -i '/nrdp' /var/log/httpd/ssl_error_log
grep -i '/nrdp' /var/log/httpd/access_log
grep -i '/nrdp' /var/log/httpd/ssl_access_log
