I am trying to monitor a router in a dmz. For some reason everything appears to communicate properly except for the bandwidth stats they all report back 0 in 0 out. I am wondering if this is from the router setup or could it be a firewall issue ? All of our internal routers report back proper stats. What port / protocol is need for this check ?
check_xi_service_mrtgtraf!xxx.xxx.xxx.xxx.rrd!500,500!800,800!M!!!!
Comm issue behind firewall
sreinhardt
- -fno-stack-protector
Re: Comm issue behind firewall
This is snmp get requests, which are over port 161 generally, and use udp. It is entirely possible that mrtg is not getting data returned, so it fills zeros or nans, which the bandwidth check that looks at mrtg rrds is reporting 0 because of this. You can test snmp connectivity with:
nmap -sU -p 161 [hostname\ip]Nagios-Plugins maintainer exclusively, unless you have other C language bugs with open-source nagios projects, then I am happy to help! Please pm or use other communication to alert me to issues as I no longer track the forum.
thank you I will further troubleshoot and get back
nmap results look good
Is the community correct? Can you walk the host?
or:
snmpwalk -c <community> -v1 <ip of remote host>Code: Select all
snmpwalk -c <community> -v2c <ip of remote host>Former Nagios employee
What type of firewall is this? I know for a fact that bandwidth on a Cisco ASA uses a different OID than the router/switch. Can you do a SNMP get to see if the OID you are using is providing a value?
btemple, did you get a chance to look at abrist or dfmco's answers?
