SNMPTT not converting mibs
ksric
Post by ksric »
I have installed snmptt 1.4 on my Nagios core 3 in a Test box and I have setup snmptrapd and snmptt.ini file as per documentation in snmptt.
I am now trying to run snmpconvertmib utility to convert a cisco MIb file but I am getting constant error as 'Cannot adopt OID'. I am running all the programs using Root user. Do we need to create snmptt user as well.
The error output shows some module files are missing. How and where do I get this?
Someone kindly help.
Regards,
Sricharan
+61-0416629626
CISCO-WIRELESS-NOTIFICATION-MIB.txt
MIB file I am trying to load
(32 KiB) Downloaded 222 times
error.txt
Output of snmpconvertmib utility
(5.67 KiB) Downloaded 232 times
abrist
Red Shirt
Re: SNMPTT not converting mibs
Post by abrist »
The following errors:
Cannot find module (CISCO-TC): At line 31 in /usr/share/snmp/CISCO-WIRELESS-NOTIFICATION-MIB.my
Cannot find module (CISCO-SMI): At line 33 in /usr/share/snmp/CISCO-WIRELESS-NOTIFICATION-MIB.my
Imply that the MIB you are trying to add requires 2 other MIBS: CISCO-TC and CISCO-SMI.
The subsequent "Cannot Adopt" errors are derivatives of those missing MIB errors. You will need to install/convert those two MIBS first.
ksric
Post by ksric »
Thank you for your help.
Regards,
Sricharan
