Would it be possible to get separate NagiosXI patches incorporated to the particular upgrade package ??
Is there maybe some way to get it from the upgrade package ?
We had many problems lately making an upgrade using the upgrade package, and it would be more comfortable to have the control on what's changed and what stays intact.
Kind regards
Michalux
NagiosXI patches ?
Re: NagiosXI patches ?
pzusa,
At this time there are no plans for separate patches, however, the actual ./upgrade script isn't locked, so if you really wanted to open it up and apply the changes you want. So feel free to look at that before running it. We cannot guarantee that Nagios XI will run properly if you do not run that scrip for an upgrade though.
Nicholas Scott
Thanks for the info.
I'll try to look at the upgrade script ...
Take care
Michalux
Take care
Michalux
