Graph Template not being used
Ray.Livesley
I created a service and am sending passive checks with performance data to the service and the performance data is being received and displayed using the default graph template. I want to change the format of the graphs, so I created a check plugin (a dummy as I plan to still us passive checking), setup a command fro this and associated this with the service to which I sending passive checks/performance data. I then created a graph template from the default and made some simple changes and loaded this with the same name as the check plug-in and command. However, Nagios XI is still using the default template rather than my modified template. Any ideas? I have noticed that the owner and group ids of the new template are both set to 48 - whilst the group id if the other templates in 500. Is there something wrong with the user/group setup?
Ray
Ray
sreinhardt
- -fno-stack-protector
Re: Graph Template not being used
Can you show how the service is currently configured, the templates that you configured, and the current permissions please? Most likely this is just a naming mixup. From my understanding pnp should respect the active checks name as a template name and attempt to use that specifically with fallback to generic templates.
Ray.Livesley
I hope this is what you are looking for:
host_name imgee-master.kl.imgtec.org
service_description TC2 Status
check_command check_mc_usage
max_check_attempts 3
check_interval 5
retry_interval 1
active_checks_enabled 0
passive_checks_enabled 1
check_period none
notification_period none
notifications_enabled 1
contacts null
contact_groups null
register 1
command_name check_mc_usage
command_line $USER1$/check_mc_usage.php -h
Information from Graph Templates page in XI:
File: check_mc_usage.php
Directory: templates
Owner: 48
Group: 48
Permissions: rw-rw-r--
Regards
Ray
check_interval 5
retry_interval 1
check_period none
contacts null
contact_groups null
register 1
Owner: 48
Group: 48
Regards
Ray
Most likely. You should see some errors relating to it in the log: /var/log/httpd/error_logRay.Livesley wrote: Is there something wrong with the user/group setup?
Lets check your group config:
grep "nag\|apache" /etc/groupFormer Nagios employee
Ray.Livesley
We have changed the group permission, but this has no effect.
However, we have noticed that none of the XI templates appear to be being used. Have the same format etc. Is there something we need to do to enable the use of the templates in XI?
Ray
Ray
- Box293
- Too Basu
Can you please post a screenshot so we can see how the templates are not being used.
jaroslaw.kapica@it
I'm working with Ray, and have a follow up on this.
I have set new dummy service "Birds count" that serves the purpose of creating a graph with stacked values.
Below is current image: As you can see, the values are displayed individually, rather as stack.
Below I'm grepping few files that may seem relevant directly from server terminal
* no writes have been done in terminal
** paths are relative to /usr/local/nagios
# ls -la ./share/pnp/templates/check_birds_count.php
-rw-rw-r-- 1 apache apache 1508 Sep 8 10:57 ./share/pnp/templates/check_birds_count.php
File ./share/pnp/templates/check_birds_count.php: There are two important lines there that indicates to me this file is not used:
Line 41: With ''Birds on ' inserted to the title
Line 45: With word "STACK" added (following http://oss.oetiker.ch/rrdtool/doc/rrdgr ... ph.en.html)
# grep -A2 -B1 check_birds_count ./etc/commands.cfg
command_name check_birds_count
command_line $USER1$/check_dummy $ARG1$ $ARG2$
# grep -B4 -A3 check_birds_count ./etc/services/fbuildvm-linux.hh.imgtec.org.cfg
host_name fbuildvm-linux.hh.imgtec.org
service_description Birds count
check_command check_birds_count!0!"Only 5 birds|crows=2, sparrows=3"!!!!!!
check_period 24x7
register 1
File ./share/perfdata/fbuildvm-linux.hh.imgtec.org/Birds_count.xml To be honest, I'm not sure if I'm on right track at all. The template code seems to follow the rrdtool notation, but the graphs doesn't seem to be comming from rrdtool at all.
Best regards,
Jarek
check_period 24x7
register 1
Best regards,
Jarek
- Box293
- Too Basu
Hey Jack,
I love the birds count, great way to visualize without the complications LOL.
OK the screenshot was exactly what we needed.
Your graphs are currently being generated using the newer Highcharts module, this is why your templates are not being used.
To switch back to PNP:
- Click the Admin menu
Under System Config click Manage System Config
Under Default Display/Theme Settings
Un-tick the box "Use Highcharts for Perfdata Graphs"
Click the Update Settings button
jaroslaw.kapica@it
This has changed the "Performance graphs" to pnp/rrdtool images. Looks like the template is being used now, as title changes are reflected on the image. NB. Only one value (crows) is plotted. I suppose the template needs more fine tuning.
Can you recommend any template as an example how to make stacked graph?
Still in View->My View->Service detail, when clicking on graph preview link, the displayed graph is Highcharts. Shouln't that change to pnp/rrdtool too?
Regards,
Jarek
Regards,
Jarek
- Box293
- Too Basu
This was an added feature of the Graph explorer (highcharts), it does not revert to pnp. Nagios XI is moving towards the highcharts as the preferred graphing engine so I don't think this will be something that will be changed.jaroslaw.kapica@it wrote:Still in View->My View->Service detail, when clicking on graph preview link, the displayed graph is Highcharts.
As for stacking with PNP, this can be done. It's like using AREA but a STACK goes on top of an existing AREA (if memory serves me right).
A lot of the documentation about this can be found on the rrdtool website:
http://oss.oetiker.ch/rrdtool/doc/rrdgr ... es.en.html
http://oss.oetiker.ch/rrdtool/tut/rrd-beginners.en.html
