Hi all.
I'm trying to upload this plugin: http://exchange.nagios.org/directory/Pl ... TK/details
But it fails every time I try to upload it saying that the folder permissions may not be right. Any ideas on how to fix this?
Upload check_ad plugin failing
cwscribner
Re: Upload check_ad plugin failing
Can you do this on your Nagios XI server?
And post the output?
ll /usr/local/nagios/Nicholas Scott
cwscribner
total 48
drwxr-xr-x 2 nagios nagios 4096 Jun 22 23:47 bin
drwxrwsr-x 7 apache nagios 4096 Jul 22 11:56 etc
drwxr-xr-x 2 nagios nagios 4096 Jul 20 16:09 libexec
drwxrwxr-x 2 nagios nagios 4096 Apr 21 12:07 sbin
drwxrwxr-x 12 nagios nagios 4096 Apr 21 12:11 share
drwxrwxr-x 6 nagios nagios 4096 Jul 25 13:53 var
Can you try
Then try to upload your plugin again?
Just to see if thats the issue?
chown nagios.apache /usr/local/nagios/libexec
chmod 775 /usr/local/nagios/libexecJust to see if thats the issue?
Nicholas Scott
cwscribner
I managed to upload the .pl file in the archive but it won't take the whole .zip file. Not sure if that will be a problem...
I don't believe uploading only the "check_ad.pl" file will do the trick. We will do some testing and will get back to you.
cwscribner
Any updates on this?
That check_ad plugin has to be used in conjunction with NSClient++. The author of the plugin made this post:
http://www.itefix.no/i2/node/11970#comment-14777
Which gives a pretty good synopsis of what you'll need to do.
Nicholas Scott
