When we try to delete a contact we are receiving the following error:
Database Relationships for contact : user.name
Items labeled as: 'Dependent relationships' will prohibit deletion
Object ID: 3 of table tbl_contact:
Relation to Commands, entry: check_none
This is only a contact and does not have a user account created. Any help would be much appreciated.
Cannot Delete Contact
Re: Cannot Delete Contact
I presume you are running 2014r1.4. This is a bug. It has been fixed in the next version. You can still delete objects in the CCM by checking the box and then using the "With Checked" dropdown to delete them.
Wow. It was right there just overlooked it. Thank you for the help!!!
